Mustang Forums at StangNet
Need Help Fast!
This is a discussion on Need Help Fast! within the 2005 - 2009 Talk forums, part of the 2005 - 2009 (S-197) Mustang category; Well I am looking at a salvage 07 mustang and it says that it needs a engine crank. i have ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-30-09, 10:38 PM
Need Help Fast!
Well I am looking at a salvage 07 mustang and it says that it needs a engine crank. i have been up all night looking for one. can someone tell me what it is or where i can get one ?
Thanks in advance
  #2 (permalink)
Old 09-30-09, 10:50 PM
Wraith413's Avatar
Garage
That would be the engine crankshaft. It is the major rotating assembly in the motor that the pistons and connecting rods are connected to. More than likely, if the motor has a bad crank, it probably has other bad parts.
This could include ;
the crankshaft bearings, damaged pistons/connecting rods, cylinder wall scoring/gouging and possible head/valve and or other valve train damage. The only way to know for sure is a complete tear down and inspection of the motor.
  #3 (permalink)
Old 10-01-09, 05:46 AM
ct07gt's Avatar
Official Member
Is the engine failure the only problem with the car? It could be a good deal if you are looking to go to a forged setup. If there are other problems on top of a bad engine, you are probably better off looking somewhere else for a car.
  #4 (permalink)
Old 10-01-09, 06:25 AM
the person who has it says that it only has a bad engine cradle and its $7000
  #5 (permalink)
Old 10-01-09, 09:02 AM
J.Cagle's Avatar
Official Member
Garage
That doesnt sound like too bad of a deal really. You can usually pick up a mustang 3v 4.6 for around $2,500. Then you could just swap out the entire motor and away you go.
  #6 (permalink)
Old 10-02-09, 04:08 PM
bluecar's Avatar
Right off hand, I personally would not do it. What other damage did the car sustain and how much would it cost to fix? Would a used Mustang cost less in the long run? Just my thoughts. Good luck in your decision.
  #7 (permalink)
Old 10-02-09, 04:39 PM
Official Member
A salvage title can also pose problems. I would check out a good, used 07 GT. That likely would be the cheapest route all away round.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
