Mustang Forums at StangNet
Fuel Pump Control
This is a discussion on Fuel Pump Control within the 5.0 Tech forums, part of the 5.0 Mustang category; I have a 94 mustang with a built 408w in it. I am in the process of setting up my ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-04-09, 10:49 AM
moosetang408w's Avatar
Fuel Pump Control
I have a 94 mustang with a built 408w in it. I am in the process of setting up my engine control unit (Vipec V44). On this unit I have an auxilary output that will switch a relay for my fuel pump (inline A1000 Aeromotive pump). So equipment wise I have a controller capable of Pulse Width Modulation, a very fast switching solid state relay, and a pump that is more than enough. My question is that I want to have my pump slow down when I don't need the fuel supply so what is a good choice for switching speeds and duty cycles. The pump is rated to 1000hp and my engine makes 500hp and 650 on the juice.
Hz:??????
Duty Cycle(500rpm): ???
Duty Cycle(1000rpm):???
Duty Cycle(2000rpm):???
Duty Cycle(3000rpm):???
Duty Cycle(4000rpm):100%
Duty Cycle(5000rpm):100%
Duty Cycle(6000rpm):100%
Thank you in advance
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
