Mustang Forums at StangNet
hanging idle!
This is a discussion on hanging idle! within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; After my car is warm, it hangs the idle around 2,000 rpm for a few secs before dropping down to ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-07-09, 07:11 PM
OrangeMustangGt's Avatar
hanging idle!
After my car is warm, it hangs the idle around 2,000 rpm for a few secs before dropping down to ~1000 where it should be. I had it fixed on my old tune, but by mistake I wiped it. Can anyone remember what I have to change? I tried messing with the dashpot decay table, but it only seemed to have effect when not moving.....
  #2 (permalink)
Old 10-09-09, 04:34 PM
I have the same problem idle also a problem. New 331 stroker X303 cam AFR Alum heads Trick flow intake New MFA MSD dist. everything done right now have it at prof tunner for past week still have surge and idle problems infact it is getting worse. Tuner has put in new ecu still not working Any suggestions
  #3 (permalink)
Old 10-10-09, 07:10 AM
What did you do to correct problem???
  #4 (permalink)
Old 10-10-09, 09:30 AM
final5-0's Avatar
Official Member
Quote:
Kyle
Several thoughts about the nagging issue you speak of here
I can say I've seen it crop up on ALL tunes I have built in the past
I've ran tunes based off of t4m0 & j4j1
Its been my finding its more likely to happen on the t4m0
Idle issues can be VERY frustrating as SO MANY things control it
First things first
As like most different areas in the tune
It is an ... ABSOLUTE MUST ... to make sure
You ain't got mechanical junk hosin up your tuning efforts
In this case ...
Make sure the t b stop screw is not holding the blade too far out
and
You don't have the tb bleed screw too far out
Look in these areas of the tune to help
and
I must confess ... I've forgotten a bunch of the specific details
but
I'll do the best I can to describe from memory
Scalar ... I think ... Throttle Body airflow
ISC duty cycle ... forget where it is
This one table will make a big difference on idle
Neutral Idle Airflow or something close to that
Basically ... You use this table to reflect airflow at different rpm
In a nutshell you datalog at different rpm's and plug in the data
seen from the dl file
You can use feeler gauges to up the idle speed while testing
Sorry to be so generic with my help but I just haven't done any tuning
for so long and I've just lost a lot of that stuff but all this stuff is
documented all over the tuning forums
and
If you search back WAY BACK THERE when I was involved ......
I've documented all that junk on our site more than once
but it is gonna be 2 to 4 years back
Might be that I covered this stuff on my site
but
I can't remember a lot about what I put up there as well
Now that I think about it
seems like
Wes talked about that table like maybe within the past month
anyway ...
maybe that will get you started in the right direction my friend
Grady
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
