Mustang Forums at StangNet
95 gt temp gauge problem?
This is a discussion on 95 gt temp gauge problem? within the 94-95 Talk forums, part of the 94-95 Tech category; 95 gt. The temp gauge has been acting weird going back and forth. When i first start the car it ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-08-09, 11:21 PM
95 gt. The temp gauge has been acting weird going back and forth. When i first start the car it will work its way up to middle then eventually all the way to hot. So i get out and their is no steam or anything i even put my hand on the top of the engine and it isnt even warm. I have the advance set to 15 with 91 octane. All stock. All of my other gauges seem to work fine and i recently replaced my thermostat and have full coolant.
  #2 (permalink)
Old 10-09-09, 01:34 AM
HISSIN50's Avatar
"How long do you think it'll take me to get any help?" --Richard Harris
How recently did you have the system open? Air in the system can cause erratic gauge readings.
  #3 (permalink)
Old 10-09-09, 08:08 AM
nmcgrawj's Avatar
Official Member
Take off the radiator cap and just run it open for a while and let the thermostat cycle open and closed. Squeeze the upper radiator hose just to give any air in the system extra motivation to move. If that doesnt work you may want to hook up an aftermarket temp gauge just to see exactly what its doing.
Does it stay on "hot" once it goes up? What thermostat did u put in? Are you sure its opening?
  #4 (permalink)
Old 10-09-09, 01:10 PM
i dont know what brand of thermostat i put in but i bought it at napa and it was the more expensive one. The guage will start out at cold then slowly work up to eventually getting to hot. But before my new thermostat was put it it overheated and was steaming and the guage didnt even read all the way hot. And now it reads all the way hot but i can touch the engine. when i turn off the car it goes back to cold and raises slowly.
  #5 (permalink)
Old 10-09-09, 01:22 PM
nmcgrawj's Avatar
Official Member
Get an aftermarket gauge on there or replace the factory temperature gauge sender....
If the gauge reads hot, yet the engine isnt hot....then something isnt right. Is ANY part of the cooling system hot? Radiator? DOes it blow hot air?
  #6 (permalink)
Old 10-09-09, 01:27 PM
Chythar's Avatar
Official Member
Sounds to me that the CTS (coolant temperature sensor) may have failed, or the connection is loose. The CTS is the brass sensor just to the right of the distributor. It has a black "L" shaped rubber plug on it. Inside the plug are two metal pieces that grip the CTS. Try to squeeze the plug so the metal pieces are closer together. See if that helps.
It would help if you had a code reader that can read PIDs (engine sensors, basically). You could then see the temperature that the computer sees. Where do you live, mustang11? If you're in Los Angeles somewhere I can help you out.
  #7 (permalink)
Old 10-09-09, 10:07 PM
Official Member
Sounds like it could be a blown head gasket. My gauge did the same thing when I blew the head gasket.
Kurt
  #8 (permalink)
Old 10-10-09, 10:30 AM
mine did the same thing when I replaced the thermostat because I didn't get the air out of the system. AS they said get the car up to temp with the cap off and squeeze the upper hose to work the bubble through that forms in that hose.
if that doesn't work then you can start throwing parts at it, but start simple.
  #9 (permalink)
Old 10-10-09, 01:17 PM
when i took the radiator cap off and drove it coolant shot out the cap all over the place. so i put it back on and drove it for awhile then the gauge went to hot again but no steaming from engine or anything still cool enough for me to put my hand on it. But when i parked i heard gurgling in the coolant resivoir. when i pinch the little hose that goes from the radiator cap to the coolant reservior it stops gurgling.
  #10 (permalink)
Old 10-10-09, 02:35 PM
Quote:
Oh man, You are supposed to sqeeze the upper radiator hose while you are driving it with everything spraing out.
just kidding DUDE, did I say anywhere in the instructions to drive it with the cap off? You are supposed to do all that with it idleing........
now go back out and fill yer radiator back up, check the coolant level and then repeat my instructions. This time just let the car idle until it heats up(with the cap off). DO NOT DRIVE IT but once you feel the upper hose heat up, just give it a couple of light sqeezes. That gurgling noise you heard was the air escaping. Went that bubble gets through the system, and back out the cap you should be fine.
  #11 (permalink)
Old 10-10-09, 06:07 PM
i did the radiator cap thing. It blows hot air at first then sometimes warm. The temp of the air blowing from the heater gets warm then hot then warm. If i turn the heater off for a while then turn it on it blows way hot air then when i leave on it gets way cooler.
  #12 (permalink)
Old 10-11-09, 12:57 AM
SableSal's Avatar
You have air in the system. Do as mentioned above and you'll be good.
  #13 (permalink)
Old 10-16-09, 01:07 PM
thanks
did as you guys said and it fixed the problem
  #14 (permalink)
Old 10-16-09, 01:17 PM
nmcgrawj's Avatar
Official Member
glad to hear! What exactly fixed it?
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
