Mustang Forums at StangNet
Build an 8.8 axle or swap in a 9 inch
This is a discussion on Build an 8.8 axle or swap in a 9 inch within the 94-95 Talk forums, part of the 94-95 Tech category; I am having some issues on this topic and was wondering what everyone thought. I have a stock 8.8 axle ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-09-09, 03:34 PM
BLOWN347STROKER's Avatar
Official Member
I am having some issues on this topic and was wondering what everyone thought. I have a stock 8.8 axle under my car. With the current setup I have I have already snapped a stock axle shaft off. I just put another stock one in the rearend for now because i already had one. I was just wondering what you guys thought would be the best route to go. Should I build up my 8.8 with tube braces, axles, and spool or should I just switch to a 9 inch and build one of those.
  #2 (permalink)
Old 10-09-09, 04:54 PM
final5-0's Avatar
Official Member
9" is stout for sure
Then again ... it weighs more than the 8.8
Nice thing about the 9" is you can quickly swap out the punkin
and you got a different ratio
Another thing about going 9" is you will have to deal with
modifying it or buying one already setup to fit your Stang
I gotta tell ya ..... Them 9 inchers are tough
I used to do full on launches at strips all stuck up with VHT
at 5 to 6K with wrinkle wall slicks and never broke nuthin
Grady
  #3 (permalink)
Old 10-09-09, 05:17 PM
Official Member
were using a built 8.8 or a 9 inch for that.
  #4 (permalink)
Old 10-09-09, 10:02 PM
Official Member
You can run an 8 second quarter mile on a properly setup 8.8. The 9" has a lot more parasitic drag, and is going to slow you down. Definately go with an 8.8.
Kurt
  #5 (permalink)
Old 10-10-09, 10:13 PM
GTA_V6_Mustang's Avatar
Official Member
Quote:
Kurt
I second that, Just build the 8.8. Weld the tubes get a good diff with some axles and your good.
  #6 (permalink)
Old 10-11-09, 12:40 PM
Official Member
Quote:
And an axle girdle is a good investment too. They aren't that expensive.
Kurt
  #7 (permalink)
Old 10-12-09, 11:24 AM
Official Member
Thanks for the input guys. I am going to stick with my 8.8
  #8 (permalink)
Old 10-13-09, 08:53 AM
ProKiller's Avatar
in the end i think the 8.8 would be cheaper too
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
