Mustang Forums at StangNet
interior cabin fan does not work on first 2 settings
This is a discussion on interior cabin fan does not work on first 2 settings within the V6 Tech forums, part of the 94-04 V6 Mustang category; interior cabin fan does not work on first 2 settings is there a fuse i can check or is it ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-14-09, 03:43 AM
interior cabin fan does not work on first 2 settings is there a fuse i can check or is it part of a bigger problem?
  #2 (permalink)
Old 10-18-09, 01:03 AM
MustangLX-5.0's Avatar
First two? There are 4 speeds. The very back position is Low speed, not off. It's not a fuse issue. The problem is the blower motor resistor circuit. The thermistor (which is temp sensitive) on the resistor board is bad, or the leads on the thermistor are highly corroded. You can find the resistor circuit attached to the blower motor. Look right under the dash right under and behind the glovebox. You'll see a wire harness with about 4 wires attached. Where it plugs in, you'll see 2 screws. Unplug the harness and remove both screws. It should fall right out. New part is about $15 or so.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
