Mustang Forums at StangNet
Difference between the years 05-09?
This is a discussion on Difference between the years 05-09? within the 2005 - 2009 GT Tech forums, part of the 2005 - 2009 (S-197) Mustang category; What did they change between the years?...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 GT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-15-09, 10:25 AM
  #2 (permalink)
Old 10-16-09, 07:52 PM
tommyroc's Avatar
Official Member
Garage
Not too much, the suspension was retuned for 2007 and then again retuned for 08 and 09. 2007 was 1st year for navi and heated seat option. Rim options. Some other minor things here and there nothing that worth looking at one or the other if you are able to get a really good deal on one.
  #3 (permalink)
Old 10-16-09, 09:31 PM
walter's Avatar
07+ models have more trim levels, Shelby, GT500, Bullitt.
07+ models have a different computer which requires a different tuner (if you go with a diablosport) and in some supercharger packages an install kit for them.
07+ models have also more chassis stiffening then the 05-06 models.
07+ models have a better and simpler designed routing for the cooling system.
07+ models come with a TPMS system.
07+ models are usually more expensive.
latter 08-09 models should have the redesigned cylinder head with the more traditional one piece spark plugs which don't fail when you try to remove them.
Starting to sound like the commandments here.
That's all I can think of for now.
  #4 (permalink)
Old 10-17-09, 12:45 AM
My rearend needs a stud and two nuts.
Walter hit the most important ones, but I would recommend an '08 or '09 because most of the bugs (TSB's) have been worked out of them.
  #5 (permalink)
Old 10-17-09, 01:25 AM
ViperNuge's Avatar
Official Member
Quote:
Great, now you tell me after I bought my 06!
patrick
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
