Mustang Forums at StangNet
96 V6 Shaking - Wrong Tires?
This is a discussion on 96 V6 Shaking - Wrong Tires? within the V6 Tech forums, part of the 94-04 V6 Mustang category; Hey everyone. Just bought a 96 Mustang with the V6. It shakes when it hits 55 until about 65 or ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-17-09, 02:33 AM
It shakes when it hits 55 until about 65 or so. I'm thinking its because of the low-profile tires. Going to throw on a new set of tires and get an alignment tomorrow. Pretty sure this will take care of the problem.
Any insights or suggestions?
  #2 (permalink)
Old 10-17-09, 10:30 AM
bdcardinal's Avatar
tree hugger
if the tread isnt separating, then its probably just a balance issue.
  #3 (permalink)
Old 10-17-09, 12:56 PM
Official Member
Check the driveshaft bolts. My car had a vibration after 45 mph when I took the load off the drivetrain. Got under there, and noticed that 2 of my 4 DS bolts were backing out...
  #4 (permalink)
Old 10-17-09, 09:26 PM
Mustang5L5's Avatar
Garage
Just rebalance the tires...no need to buy brand new ones unless they are worn or there is some defect with the tires.
  #5 (permalink)
Old 10-17-09, 11:31 PM
Follow up:
Tried to have the tires rebalanced at four different places today. Everyone kept telling me they didn't have the machine to balance my after market rims. Finally, Tire Discounters was able to balance them, but I just elected to throw on 4 different tires.
The thing I didn't see before (since I bought the car at 11 o'clock at night without the best vision) was that the tires were pretty bald.
Anyway, car no longer shakes and was able to take it the rest of the 150 miles home hitting about 85 on the freeway with issue.
Still needs aligned though, pulls really hard to the right whenever I come to a stop.
  #6 (permalink)
Old 10-18-09, 11:48 AM
bdcardinal's Avatar
tree hugger
pulling hard while braking is generally not an alignment issue, its more of a brake issue.
what type of aftermarket wheels do you have? what is the tire size?
  #7 (permalink)
Old 10-28-09, 07:15 PM
doc4444's Avatar
I had this same problem for the last few months. Same speeds and everything. Just this morning I went to Discount Tires and had to completely replace my tires, now all is smooth sailing. Take your car to a tire shop, and have them look at them. There is a good chance that your problem lies therein. Good luck!
  #8 (permalink)
Old 11-08-09, 08:31 AM
Post
There is a TSB out for vibration at highway speeds. Ive done all the listed repairs (stiffer engine mounts, new struts, wheel rotate & Balance) except for the sub frame stiffeners. Not sure if I want to install those roadkill catchers under my car? Still have a vibration around 65 - 68. Just keep it above that and all is fine! Tire pressure seems to pay a role with it to.
Here is a list of TSB's and recalls.
Ford Mustang | The Center for Autosafety
Trying to find what the TSB says without having to pay may take some digging.
  #9 (permalink)
Old 11-08-09, 03:51 PM
bdcardinal's Avatar
tree hugger
if you have the TSB number you can go into a ford dealer and ask for a copy of it. just FYI, the problem with TSBs listed on the internet is they can be incomplete or be obsolete.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
