Mustang Forums at StangNet
Msd LAUNCHMASTER
This is a discussion on Msd LAUNCHMASTER within the 2005 - 2009 GT Tech forums, part of the 2005 - 2009 (S-197) Mustang category; JUST purchased a launchmaster instructions tell me to connect to clutch pedal switch using blue/red wire but my 2008 has ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 GT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-18-09, 10:48 AM
Msd LAUNCHMASTER
JUST purchased a launchmaster instructions tell me to connect to clutch pedal switch using blue/red wire but my 2008 has 1white and 1 black wire and do not know which one to tap into to ground.let me know if anyone has overcome this problem thanks
  #2 (permalink)
Old 10-18-09, 01:46 PM
DarkFireGT's Avatar
kooldawg's better half
I didn't tap into the stock switches. If I remember correctly, if you do that, you will lose the automatic cruise cancel when the clutch is pressed. Here's my install write-up:
S197 Ford Mustang MSD Launch Master Install | StangNet
  #3 (permalink)
Old 10-18-09, 04:14 PM
i was in the wrong harness the color coding is blue/yellow wire on the lower clutch switch i was looking at the upper clutch switch.i am gonna put a toggle switch in the negative ground wire so i can have it work only when the toggle is activated.thanks for the info.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
