Mustang Forums at StangNet
Plug Wires
This is a discussion on Plug Wires within the 2005 - 2009 Talk forums, part of the 2005 - 2009 (S-197) Mustang category; At what point did Ford start going with the plug wires that are apart of a larger wiring harness? I ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-18-09, 06:39 PM
Adverse2Change's Avatar
Official Member
Plug Wires
At what point did Ford start going with the plug wires that are apart of a larger wiring harness? I first noticed it on my '06 Focus, and again on my '09 GT. Is this style better than a more traditional type of plug wire setup? How exactly would you go about changing the wires... or can you even?
  #2 (permalink)
Old 10-18-09, 07:06 PM
klaw's Avatar
Official Member
Garage
Our cars have a coil on each plug whereas a conventional old-style iginition had one coil and distributed the high voltage through high voltage plug wires. You don't need to change the plug wires in our setup but on occasion you might have to replace a coil (referred to as a "COP" - "Coil-On-Plug"). With our setup the high voltage side of the coil is connected directly to the spark plug.
  #3 (permalink)
Old 10-18-09, 07:24 PM
DarkFireGT's Avatar
kooldawg's better half
Right. Plug wires were changed in the past to put on lower resistance wires (either by thicker wire or more conductive material), so that the power between the coil and the sparkplug was not lost. Since we have coil-on-plugs, that's not necessary. All the action takes place right there.
  #4 (permalink)
Old 10-18-09, 07:43 PM
Official Member
Awesome, thanks for the replies.
  #5 (permalink)
Old 10-18-09, 09:26 PM
The Fang's Avatar
Official Member
This is something I recently noticed, I have a v6 4.0 and they are not COP design.
  #6 (permalink)
Old 10-18-09, 10:04 PM
kooldawg6's Avatar
mine works really well and can take a fair amount of pressure without bending
So what actual/noticeable gain will we get by switching out the OEM COP for an aftermarket COP??? They're several hundred $$$
  #7 (permalink)
Old 10-18-09, 10:42 PM
DarkFireGT's Avatar
Quote:
There's only a couple options available. GMS makes one, which I avoid them like the plague. I think MSD makes one too. From what I've seen, NA it doesn't do squat. The COP design is pretty efficient. If you were boosted, you might see a minor increase. Just like throttle bodies, pretty much, as I've also seen problems with the COPs.
  #8 (permalink)
Old 10-19-09, 07:34 AM
kooldawg6's Avatar
Thanks, Dark After seeing this thread I quickly checked Summit racing and saw that they have their own COP as well as Accel, MSD and GMS. No great description on actual gains and now that is money I don't have to worry about wanting to spend/waste
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
