Mustang Forums at StangNet
SN95 to fox throttle body swap?
This is a discussion on SN95 to fox throttle body swap? within the 94-95 Talk forums, part of the 94-95 Tech category; I swapped intakes on my 95 a little bit ago and i needed a sn95 throttle body adapter to run ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-25-09, 10:23 AM
Garage
I swapped intakes on my 95 a little bit ago and i needed a sn95 throttle body adapter to run my setup. What would it take to switch to a fox body throttle body? aslo when i got my car tuned i am "pegging out" my pro-m bullet mass air flow sensor and was told to get a lightning mass airflow sensor. i also have a mac cai so, if anybody knows what it takes to swap a lightning mass air and a fox body throttle body it would be greatly appreciated
  #2 (permalink)
Old 10-25-09, 05:21 PM
BlackVert's Avatar
Official Member
dude, that subject has been covered probably about a million times both here and on corral. a search will find you more info than you could ever hope for.
do you have a blower or something? what is your combo?
  #3 (permalink)
Old 10-25-09, 05:22 PM
95BlueStallion's Avatar
Official Member
Do a search on the fox throttle body swap. Its been talked about several times. As for the lightning MAF, Im not sure about that.
Edit: BlackVert beat me to it.
  #4 (permalink)
Old 10-25-09, 05:56 PM
Garage
Ok thanks. im new on here and getting used to this site. i am running a n/a stock bottom end with 115k, comp 224-232 112* .600 lift, 10.2:1, ported performer rpms 2.02-1.60, ported carbed victor jr. converted to efi, ported 70mm tb, mac 1 3/4 shorty headers, offroad h, american thunder 322rwhp@5800 when mass air pegs
  #5 (permalink)
Old 10-25-09, 07:04 PM
earleys94gt's Avatar
Official Member
sounds like you have a good combo.
  #6 (permalink)
Old 10-25-09, 11:31 PM
Adam95GT's Avatar
Official Member
Quote:
u sure your pegging that meter????
  #7 (permalink)
Old 10-26-09, 08:45 PM
Garage
At 5600 rpm running 4.882 volts
At 5800 rpm running 4.937 volts
Power still climbing at 5800
  #8 (permalink)
Old 10-26-09, 11:08 PM
BlackVert's Avatar
Official Member
sure sounds like you are pegging it ... congrats! you have a dang stout combo there
did you have to do anything to the pistons to keep the valves from hitting? that's alot of lift for stock pistons ...
also, what are you doing for an upper intake?
got a tuning device? and what injectors are you running? there are more than a few mass air meters out there to choose from. i have a lightening maf on mine
  #9 (permalink)
Old 10-26-09, 11:49 PM
Garage
not too bad for most of it it is used! all the portwork and machining was done my self.
i had to cut bigger and deeper reliefs in the stock pistons for the 2.02 -1.60
i used a flycutter that goes into the valve guides of the head so i could do it incar. im running on the edge for p to v. i didnt know how thick the pistons were and i didnt want to lose any compression. as for the intake i bought a used victor jr. for a carbed application off of ebay for cheap and machined and welded it for efi. then i bought a used 90* elbow from ebay again and chopped welded and machined so it would fit under my stock hood. i just took my car to get tuned so whatever my tuner guy uses i dont know. running 30lb injectors. had 19s in when i tried to get tuned but couldnt even get a baseline it was wayyy to lean
  #10 (permalink)
Old 10-27-09, 07:14 AM
BlackVert's Avatar
Official Member
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
