10-25-09, 11:54 AM
| | Member | | Join Date: November 2008
| | | Should I buy this car?
Once again I turn to you for help.
I went to this car show yesterday and found a 1967 cab for sale for 13700.
The car had no rust. New paint in july. It was original a 6 cyl, but he had put in a 1968 289 V8 4 barrel.
A few things needed to be fixed. The tach did not work. The turn signals did not work. A minor tear in the roofcovering.
Is this something I should go for?
Thanks!
Erik |
10-25-09, 02:56 PM
|  | White by Birth, Trash By Choice | | Join Date: September 2001 Location: Oregon.
Depends on your location, and the overall condition of the car.
$13,700 is on the high side for a plain Jane restored coupe. Especially an original 6 cylinder. |
10-26-09, 12:41 PM
|  | Official Member | | Join Date: April 2004 Location: Salt Lake City, Utah
I agree that is a lot of money for even a 289 coupe that is if it is bone stock. It also depends on whether the owner also went about setting up the car properly for a V8 since it was an original 6, a lot of things would need to be checked. I would wait you can fetch a decent stang for that price that would be more fun, I got my Mach 1 for that price 5 years ago and it was in decent condition. |
10-26-09, 03:13 PM
| | Official Member | | Join Date: February 2003 Location: Denver, CO
10-26-09, 06:18 PM
| | Founding Member | | Join Date: May 2002 Location: Sacramento Ca
Way too high. Depending on the quality of the paint job, that car should be between $6k & $8k. |
10-27-09, 12:27 AM
Allright, thanks a lot for the input guys!
Both the exterior and the interior looked to be in mint condition, but as you said I have no idea if the new 289 engine was installed correctly. As the tachometer does not work, I can imagine as it has something to do with that.
@STSFCTN67: cab=cabriolet. (or convertible as you might say..
I'll keep you updated. I have found a lot of interesting mustangs in my area for sale lately. Hopefully I'll find the right one sometime soon.
10-27-09, 06:49 PM
Where are you from? That could influence pricing quite a bit... |
10-27-09, 07:03 PM
I'm originally from Norway, but currently living in Florida. Planning to stay here for another year, then bring the car back to Norway. So I've still got about a year to find the perfect car. |
10-27-09, 08:05 PM
If it's a convertible that changes things. I thought you meant coupe, the verts fetch a higher price. Still same advice as before though, you need to be sure that all the work has been done properly to convert it to a V8. |
10-27-09, 10:07 PM
| | Member | | Join Date: October 2009
Offer him 8K and see what he says. Unless the car is turn-key and in real good unrestored condition, I'd say his number is high for an inliner 'vert, even with the conversion. An inoperative 'tach' (speedometer, I'm assuming) and a damaged convertible top can just be the tip of the iceberg of little and not-so-little things to do. |
10-29-09, 01:37 AM
|  | Official Member | | Join Date: August 2008
Do you have any pictures of it?
I would say that its probably worth about 10k from what your saying. |
10-29-09, 09:26 PM
Thanks alot for all your replies. I'm learning alot.
What is the best way to find out if the engine is 'installed' properly. Are there any things in specific I can look for?
When I said inop tach I ment the milage-'indicator'. The airspeed works fine.
I've only got one picture which I took on the carshow. I think it looks pretty decent.
Thanks again guys! |
10-29-09, 09:36 PM
That looks like a nice one. I bet the engine is installed right. What I would also check is to see if it is still 4 lug wheels or if it has been upgraded to 5 lug like the V8 cars had. |
11-01-09, 03:42 AM
being a vert makes a huge difference in the value. I am a bit rusty on the current values of convertibles. But they were going for Mid to low 20k range. In fully restored condition. (and original V8) | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
