11-01-09, 02:58 PM
|  | Founding Member | | Join Date: February 2000 Location: Chandler, Az.
| | Quote:
Originally Posted by NikwoaC I think BBF in Foxes are cool, but plan on spending WAY more money than what you would a Windsor, and with MUCH less options on combos, too. | Less options in what way? It all depends on your goals too. A 700HP BB is going to be cheaper than a 700HP SB. If you're looking for450HP, then the SB is the way to go. |
11-01-09, 03:12 PM
| | Quote:
Originally Posted by 57fairlane I've seen a few pushed quite further than that, especially with a 4-bolt main conversion.
Not to mention the motorsport blocks . . . | Yeah, I know of a certain promod that ran into the 6's with a stock block with the conversion. I have the engine systems main caps, They're BEEFY!
Them compared to a the stock 460 front cap.. |
11-01-09, 09:36 PM
| | Official Member | | Join Date: May 2008 Location: Florida
Well he wants around 500 motor, 700 on the bottle.
He could do both but the BB would be cooler. |
11-03-09, 06:37 PM
|  | Member | | Join Date: May 2008 Location: Belle River, Ont
love the big block.D&D automotive sells a complete kit for the swap. Any 4cyl or 5.0 k member works.The Mustang Depot has all the rebuild components for a decent price. I think the power brake booster is fine in your car.I believe the maximum dia. booster that fits is 7 or 8 inches,smaller the better. With aluminum heads and intake your at the same weight as a stock 351w. Had a 429 in a '78 Fairmont I once had,even kept the stock flat hood. Used stock height 302 with air coil springs.Killer low end torque. Couldn't keep tires long enough. Great swap,lots of fun. Had almost 480 hp and almost a dead stock idle,not tempermental, no exotic stuff,no over heating, just start it up and drive. Grandma could drive it for groceries,stop for gas and drive it back home. |
11-12-09, 02:06 PM
|  | Member | | Join Date: March 2009
well.. we're going to see how the BB does.. started tearing it down this week. and going to send it off to the machine shop to have everything checked over.
like 7upstang said planning for 500-600 on motor and then i'll decide how much to spray on top of that. |
11-13-09, 09:48 AM
| | Official Member | | Join Date: July 2009 Location: abingdon md
| | Quote:
Originally Posted by banks well.. we're going to see how the BB does.. started tearing it down this week. and going to send it off to the machine shop to have everything checked over.
like 7upstang said planning for 500-600 on motor and then i'll decide how much to spray on top of that. | whats up mang... |
11-16-09, 11:39 AM
| | Quote:
Originally Posted by srtthis whats up mang... | hey buddy.. nice to see you.
please tell me you have the answers to all my problems.. i'm thinking about going turbo now. check my thread in the gen chat on LR |
11-16-09, 11:42 AM
| | Quote:
Originally Posted by srtthis whats up mang... | what block does bob have in his car? |
11-16-09, 11:43 AM
haha turbo is the way to go man!!! if i still had my L id turbo it... |
11-16-09, 11:45 AM
| | Quote:
Originally Posted by srtthis haha turbo is the way to go man!!! if i still had my L id turbo it... | i'm trying to figure out if the block i have will handle the power from a turbo. i'd definitely wanna turn the boost up eventually and make some serious power with it. |
11-16-09, 12:50 PM
|  | Member | | Join Date: November 2009
429/460's are the way to go if you want some serious power. I've built plenty of them. Check my link below. |
11-16-09, 01:18 PM
| | Quote:
Originally Posted by beaststang 429/460's are the way to go if you want some serious power. I've built plenty of them. Check my link below. | how much power can they handle with forged internals (hbeam rods) |
11-16-09, 03:42 PM
I've built a naturally aspired 460 truck block with std size 460 forged pistons,std size 460 forged rods, and standard size 460 forged crank with main girdle that put out 720 hp on a engine dyno. If you want to throw boost at it and make more power than this I would recommend a Ford Racing Block. |
11-16-09, 09:03 PM
| | Quote:
Originally Posted by beaststang I've built a naturally aspired 460 truck block with std size 460 forged pistons,std size 460 forged rods, and standard size 460 forged crank with main girdle that put out 720 hp on a engine dyno. If you want to throw boost at it and make more power than this I would recommend a Ford Racing Block. | this is what i'm trying to figure out cause i might put a turbo on it. if not a turbo then it is definitely going to see some spray |
11-16-09, 11:00 PM
|  | Official Member | | Join Date: April 2005 Location: Oakwood, GA
| | Quote:
Originally Posted by 7upstang91 Well he wants around 500 motor, 700 on the bottle.
He could do both but the BB would be cooler. | I am building a similar motor right now . . .
466
waiting on my probe pistons to show up! its been almost two months
Eagle SIR i-beams
pp balancer (got the rods/balancer for $150, don't ask  )
D3 heads that I ported and put the 351c 4v valves in (2.19/1.74)
241/249 voodoo cam
torker II
850 race demon
I hope this thing makes 450 or so rwhp (th400) and I will be spraying 200-250. Or whatever it takes to get in the 5s 1/8
Personally for a dirt cheap build I would do a BBC/th400 with a motor plate but I got the rods and balancer for a song and picked up the '73 long block from a friend of mine for $80. Besides a ford in a ford sounds better.
I split my sbf block with a turbo awhile back and was never happy with the carb I converted to blow-thru. I also had a steep learning curve with the BRPV and felt that I could have been racing a LONG time ago had I done a nitrous combo.
11-16-09, 11:03 PM
| | Quote:
Originally Posted by Dark Knight Yeah, I know of a certain promod that ran into the 6's with a stock block with the conversion. I have the engine systems main caps, They're BEEFY!
Them compared to a the stock 460 front cap.. | thats hauling!
I know of personally a mustang that ran consistent 5.0s @ 150ish with a stock block and some chinese 4-bolt main caps. |
11-17-09, 10:23 AM
if it gets the turbo its going to be converted to efi. after talking with a few other people, i think i have decided to pursue the turbo. i've got a lot of stuff to do to the car first so that will give me more time to research and decide what i want to do |
11-17-09, 10:13 PM
|  | Official Member | | Join Date: June 2004 Location: The mistake on the lake (Ohio)
| | Quote:
Originally Posted by faststang90 if u want power brakes u are going to need k member spacers  | That is not true. I used stock k-member, no spacers. runnin power brakes and the motor clears the booster with the tall valve covers, and FRPP swap mounts, P/S, alternator, and e-water pump with a one-off serpentine setup.
Heres a two year old pic with the serp setup off .
And if i could do it again, i'd go bulletproof small block 331ci, single turbo.
11-18-09, 07:11 AM
| | Quote:
Originally Posted by banks what block does bob have in his car? | an RDI aluminum block... good luck finding one think don said they havent made them in like 6 years... and if you do find one, youll put a big dent in your bank account
11-18-09, 08:07 AM
does anyone have detailed pics of plug access of a bb in a fox with long tubes? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
