Mustang Forums at StangNet
big block in a fox
This is a discussion on big block in a fox within the 5.0 Tech forums, part of the 5.0 Mustang category; i'm starting to gather some info and putting together a parts list to start my build. what is needed to ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-26-09, 02:09 PM
banks's Avatar
big block in a fox
i'm starting to gather some info and putting together a parts list to start my build. what is needed to put a big block in a foxbody? its a 93 hatch and i'm planning on putting a tubular k-member in it (not sure on what brand though).
Just wondering if there is a specific k-member that i need to get or make custom mounts for the motor to fit the k member?
  #2 (permalink)
Old 10-26-09, 02:34 PM
Official Member
they sell motor mounts. the k members the same any 1 u want to use. headers they sell hooker,kooks,accufab, or u can get custom headers.
  #3 (permalink)
Old 10-26-09, 05:23 PM
banks's Avatar
Quote:
cool, thanks for help, do you know where i could get the mounts and any specific brand?
  #4 (permalink)
Old 10-26-09, 06:40 PM
ID89GT's Avatar
Official Member
There is a guy sellling big block motor mounts and headers local of me, he's had them on craigslist for at least a couple months
  #5 (permalink)
Old 10-26-09, 08:16 PM
banks's Avatar
Quote:
do you have the craig's list link?
  #6 (permalink)
Old 10-26-09, 09:13 PM
Official Member
jegs or summit sells it all
Ford Racing #397-M-6038-A460 is the 1 i had
headers here
Exhaust
if u use 175 pound springs if u have after market heads
also they sell k member spacers so u can use a stock hood
KitInfo
  #7 (permalink)
Old 10-27-09, 06:20 AM
Official Member
That sounds like a great project. Wall to wall motor. I think you may have to go with manual brakes. I think if you look up holcomb motorsports they used to sell swap kits for 351 and 460 into a fox.
  #8 (permalink)
Old 10-27-09, 07:09 AM
Official Member
no u dont have to go to manual brakes
  #9 (permalink)
Old 10-27-09, 09:12 AM
banks's Avatar
thanks for all the great info guys.. keep it coming
headers here
Exhaust
KitInfo
on accufabs website it only show headers for a 460 and i'll be using a 429, will they still bolt up to the 429 or will i have to find something different?
  #10 (permalink)
Old 10-27-09, 11:09 AM
Official Member
i have not done a 429 but the 429 is .022 shorter block than the 460 so it not a big deal
  #11 (permalink)
Old 10-27-09, 12:01 PM
banks's Avatar
ok thanks, definitely going to be doing a lot of research before i start buying stuff. want to make sure the bigblock is the way i wanna go which i'm quite certain it is.
  #12 (permalink)
Old 10-27-09, 12:07 PM
90lxcoupe's Avatar
Official Member
Quote:
the idea of a big block looks cool on paper but with the ability to have a 427 or even 466 cube SBF i just dont see the reason anyone would want to put all that extra weight on the front end.
  #13 (permalink)
Old 10-27-09, 12:25 PM
Cobra912's Avatar
Official Member
Quote:
it will only be as good as the parts going into it. I've seen guys putting in 460's or similar in their foxes just to find out they aren't as fast as they thought they would be. Then have a tough time selling them.
  #14 (permalink)
Old 10-27-09, 01:05 PM
Dark Knight's Avatar
Because for the same $$ it takes to build a 466 SBF, you'd have a 557" BB..
Weight isn't that big of a deal, 260LBS more.. less with aluminum heads. BTW, the stock 4290/460 block is good to around 800 HP
  #15 (permalink)
Old 10-27-09, 01:22 PM
90lxcoupe's Avatar
Official Member
Quote:
260 isnt that much?! thats like driving around with a 2.3 litre under the hood on top of your motor. and its in the worst spot right on the nose, good luck getting the car to transfer any weight. Ive got a friend with a 460/C4.9inch. stock heads/bottom end with spray, he blows em up all the time and it runs low 12's on motor and low 11's on a 150 shot. He has had issues FOREVER with getting the car to hook at all.
  #16 (permalink)
Old 10-27-09, 04:19 PM
tannerc91gt's Avatar
Official Member
The 460 being good to 800 isn't much of an accomplishment when the 351w goes 700 and with nearly 300 less pounds. There's a kid where I live with a 460 in a 71 mustang, i outran him in a '94 chevy 1500 truck haha.
  #17 (permalink)
Old 10-27-09, 06:12 PM
Official Member
u can do it with a sbf but i just wanted something different than all other mustangs. i had a A block,A heads,billet crank,billet rods,danny b belt drive and i had alot of money in that motor u can do it alot easier with a 460 than a 429 because alot of parts are going to have to be custom because of the deck hieght.
i started off as a 547 with a 101 mm turbo but im going back to a 427 that will run high to mid 9s on motor
  #18 (permalink)
Old 10-27-09, 07:08 PM
banks's Avatar
if i do the big block, it will be top notch. definitely not going to cut any corners. right now i have a 429 block and a 302 roller block. i thought about stroking the 302 out to a 331 or 347 and putting some spray on it but i think i would really rather go big block with some either some flat top or domed pistons and a good set of heads and cam. i know either way i'm going to be spending a good chunk of change which is why this won't be getting done over night. its also another reason i'm on here getting all the info i can before i make a decision. My goal would be to eventually be to run mid to low 9's with the car. but i have also never built a vehicle to that caliber, which is another reason i'm trying to find out all i can. the motor will be carbed and the only power adder i want to use is spray.
  #19 (permalink)
Old 10-28-09, 10:03 AM
Make sure you look at the tech side of running 9's, ALOT more safety equipment needed than for a 10 sec car. Things like a parachute, window net, certified cage and a competition license are just a few of the things needed. Cost adds up quick unless you can do the welding etc yourself.
As for making a BB fox hook.. PLENTY of people have done it...
This would be a good streetable build
502 "PUMP GAS" 9 sec build results-2008 updates - 460 Ford Forum
  #20 (permalink)
Old 10-28-09, 02:26 PM
banks's Avatar
that stuff will all come in time. not planning on building this thing overnight. plus i can always slow the car down and not run nitrous until i get the proper safety stuff.
  #21 (permalink)
Old 10-29-09, 05:43 AM
Official Member
I thought the booster would be too close to the valve cover.
  #22 (permalink)
Old 10-29-09, 06:44 AM
Official Member
if u want power brakes u are going to need k member spacers
  #23 (permalink)
Old 10-30-09, 05:58 AM
Official Member
Thanks for the picture I havent seen a 460 fox in a very long time. I was going to do this to my 87 GT but I went with a stroked 351 for the trans options and weight. The car is geared towards handling. One day I would love to do this swap.
  #24 (permalink)
Old 10-31-09, 10:17 PM
57fairlane's Avatar
Official Member
I've seen a few pushed quite further than that, especially with a 4-bolt main conversion.
Not to mention the motorsport blocks . . .
  #25 (permalink)
Old 10-31-09, 10:43 PM
NikwoaC's Avatar
Official Member
I think BBF in Foxes are cool, but plan on spending WAY more money than what you would a Windsor, and with MUCH less options on combos, too.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
