Mustang Forums at StangNet
Help needed. Chevy Blazer 4L60E
This is a discussion on Help needed. Chevy Blazer 4L60E within the Other Auto Tech forums, part of the General Automotive Forums category; Have a 2001 Blazer that has no 2nd or 4th (OD), been told that the Sunshell is a major weaklink ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-27-09, 02:33 AM
4nEatr's Avatar
Have a 2001 Blazer that has no 2nd or 4th (OD), been told that the Sunshell is a major weaklink and cause the tranmission to do that, also been told the 1-2 Solenoid causes it as well... I ordered a rebuild kit and a HD Sunshell from Monster Transmissions before I was told about the solenoid. I heard a pop when it first started happening, thinking it was the splines on the Sunshell stripping out. drove around for a couple days and if i was easy on it, it'd go into first and OD for a bit, then kick out again... So would it be the Solenoid and i'm actually in SECOND and THIRD or the Sunshell and being in FIRST and THIRD? It shifts hard when I manually shift from 2-3 and if i put it in OD all i get is 3rd.. any help would be greatly appreciated..
thank you
Justin
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
