Mustang Forums at StangNet
power rack vs manual
This is a discussion on power rack vs manual within the MII Discussion forums, part of the Mustang II category; Hey everyone, I have been wanting to change over my power rack to a manual rack and wonder how hard ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-27-09, 12:22 PM
Hey everyone,
I have been wanting to change over my power rack to a manual rack and wonder how hard will will be to steer. I have already replaced the rag joint with a flaming river joint and I know that I will have to get another joint with the manual spline count. Just wondering if it will be worth the trouble, my power rack is worn out and is leaking bad.
thanks,
Jansen
File Type: jpg Logan Daycar pics Apri 08-Oct 08 423.jpg (208.1 KB, 14 views)
File Type: jpg Logan Daycar pics Apri 08-Oct 08 427.jpg (200.2 KB, 12 views)
  #2 (permalink)
Old 10-27-09, 07:13 PM
$50COBRAII's Avatar
Very well done!
  #3 (permalink)
Old 10-28-09, 05:58 PM
LILCBRA's Avatar
Official Member
I converted mine when I rebuilt it basically for the same reason. I would say it depends on what you want to tolerate and how wide your tires are. My fronts are 175's, so mine is relatively easy to turn. Now if I had something like 235's, it might not be so easy.
  #4 (permalink)
Old 10-28-09, 05:59 PM
LILCBRA's Avatar
Official Member
Oh yeah, your steering wheel size can help or hurt too, so take that into account as well as tire size.
  #5 (permalink)
Old 10-28-09, 09:40 PM
I have 215 yoko's up front and a grant streeing wheel. One other thing is that I did the damage to my power rack by driving it with no fluid going thru it for a year. I couldn't get the pump to work right the march pulleys I have but I got it at last and now I trashed by rack.
  #6 (permalink)
Old 10-29-09, 05:55 AM
Official Member
I just did mine for weight savings and oil pan clearance. With the 225s I had on there and the car not in motion it was hard to turn the wheel, rolling its fine. I did run a power rack with out a pump for a few years I never had any troubles with it.
  #7 (permalink)
Old 10-29-09, 09:43 AM
78CobraII's Avatar
Moderator
Garage
I've never driven a 302 powered MII with non-assist steering, but my 2.3L powered one is not too bad. It will be fine once the car gets moving, but manouvering in tight spaces at low speeds will be a challenge.
The larger diameter your steering wheel is, the more leverage you will have to turn the car at low speeds. A 15" steering wheel will be good, a 13" wheel will be tough!
  #8 (permalink)
Old 11-08-09, 11:57 PM
Slow speeds will always be a problem regauerdless of steering wheel size.I used to work at Worldport aand drove the retired STepvans that had power brakes and that it about it. If you can deal with it, its a good way to free up some engine power.
  #9 (permalink)
Old 11-09-09, 03:23 PM
Blue coyote's Avatar
i'll be swapping in a manual rack on the Rat Snake later this winter, but I drove for a while with the power rack disconnected (pump removed), 225/50R15's on the front, and a 14" Grant wheel.
When stopped, the steering is quite stiff, and even when moving, hitting the lip of the curb for a driveway got a bit snakey, but overall, I find it works fine...
  #10 (permalink)
Old 11-09-09, 03:54 PM
Yeah, good job!
  #11 (permalink)
Old 11-09-09, 06:35 PM
Sorry to butt in, but wouldn't it be nice to adapt-in a later model mustang 15:1 ratio rack instead of the 20:1 manual rack from AGR 012-712581 , say out of Jeg's Racing?
AGR Rack & Pinion - JEGS
I thought that I have read that the MII rack and the latter one's have the same 24.5" inner tie rod distance.
I have also read somewhere that there is a proportioning type valve that you could install to control the powersteering fluid flow and feel.
I could be totally wrong.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
