Mustang Forums at StangNet
Code 332 Help
This is a discussion on Code 332 Help within the 94-95 Tech forums, part of the 5.0 Mustang category; I got code 332, insufficient EGR flow? what does this mean? How to fix it. New EGR? Clean it?...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-30-09, 09:26 AM
DDSTANG94's Avatar
Official Member
Code 332 Help
  #2 (permalink)
Old 10-30-09, 09:33 AM
yukisho's Avatar
Official Member
Garage
Found this, it seems to have some info on it. Once more poeple get on, you will probably get a better answer.
egr flow insufficient - Automotive Message Forums
  #3 (permalink)
Old 10-31-09, 09:45 AM
DDSTANG94's Avatar
Official Member
ok, thanks you for the link
Im still lost tho, what to replace or clean
  #4 (permalink)
Old 10-31-09, 06:57 PM
DDSTANG94's Avatar
Official Member
No one?
  #5 (permalink)
Old 11-03-09, 05:40 PM
DDSTANG94's Avatar
Official Member
bump..someone knows
  #6 (permalink)
Old 11-04-09, 07:27 AM
BLOWN347STROKER's Avatar
Official Member
I would take off and clean/replace the egr valve. The are pretty easy to get to. Depending on how much they cost I would just replace it. I would also clean out the egr tube from the header to the valve. Another option would be to buy a block off plate and a cap for the header and a egr delete sensor plug. I think it cost me around 50.00 to delete my egr setup which in most cases is cheaper that buying a new egr valve but I would try to clean it up first if you want to keep it. It will probably end up needing replaced though. Good luck
  #7 (permalink)
Old 11-05-09, 04:41 PM
DDSTANG94's Avatar
Official Member
Quote:
Thanks..ill give cleaning it a shot...
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
