Mustang Forums at StangNet
OEM xenon projector retrofit
This is a discussion on OEM xenon projector retrofit within the 4.6 Talk forums, part of the 4.6L Mustang category; anybody got an OEM projector retrofit under their belt? got a 96 and debating what bi-xenon projector will fit best. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-30-09, 03:41 PM
sta928's Avatar
anybody got an OEM projector retrofit under their belt? got a 96 and debating what bi-xenon projector will fit best. I know people have had luck with infinity's fx projectors, but i was wondering if anybody has retro'd any e46's. I believe these are two of the smaller bx's projectors out there, but if anybody has any other ideas, they would be greatly appreciated
  #2 (permalink)
Old 10-30-09, 05:41 PM
O-G
The e46 (hella IIRC) has a less than desirable beam/cut off pattern when compared to the FX projector. I remember one guy doing an FX into a new edge, but haven't seen anything since.
If you haven't already, get on hidplanet.com and do some searching there.
  #3 (permalink)
Old 10-30-09, 06:55 PM
SRT Handz's Avatar
I tripped & fell down and cut myself & got blood
on my Abercrombie & Fitch shirt & tore my Abercrombie & Fitch shirt & now
I can't wear my Abercrombie & Fitch shirt because I got blood on it.
And it got torn, too.
Audi & S2K Projectors>*
  #4 (permalink)
Old 10-30-09, 08:21 PM
O-G
Quote:
Actually, the modded LS460 projector>S2K as far as single beams go. Wider beam pattern and just as sharp cut off line. Assuming you use the Lexus shroud of course
  #5 (permalink)
Old 10-31-09, 01:00 AM
SRT Handz's Avatar
IMO, Audi and S2K Projectors look the best in person.
being that in live in Los Angeles i have seen them all.
  #6 (permalink)
Old 10-31-09, 07:45 PM
sta928's Avatar
well i live in a rural area, so im fairly dependent on my hi beams, i wouldnt mind goin with a single xenon paired with a halogen hibeam, however i can only see this happening if i go with a set aftermarket halogen projector headlamps and retro from there? So does anybody know anything about the projectors coming out of the cadillacs and navigators. hella, bosch??
  #7 (permalink)
Old 10-31-09, 08:36 PM
O-G
My bad, he did TL's
The end all to lighting...99-04
  #8 (permalink)
Old 11-01-09, 01:33 PM
sta928's Avatar
san, good thread, thanks for posting man. much appreciated, guess i'll take this over to HIDP and see what else i can pull up
  #9 (permalink)
Old 11-01-09, 02:28 PM
O-G
IIRC I only saw one other retro into a Mustang the entire time I used to post there (but maybe more have come up since then).
Some of the peeps there are very helpful
Reply
Tags
hid, oem hid, oem xenon, retrofit
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
