Mustang Forums at StangNet
Fuel Delivery
This is a discussion on Fuel Delivery within the 94-95 Tech forums, part of the 5.0 Mustang category; Looking ahead a little on my rebuild... If I go TFS kit , would I put 24# injectors in?? Would ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-30-09, 06:23 PM
tderrick's Avatar
Official Member
Fuel Delivery
Would the stocker pump keep up??
  #2 (permalink)
Old 10-30-09, 07:42 PM
Garage
you could and as long as you stay n/a your pump will keep up, but it wouldnt hurt to upgrade the fuel pump later on. 19's could possibly still maintain, but it would be easier and without a doubt with the 24's, make sure you have the right meter for the injectors
  #3 (permalink)
Old 10-31-09, 06:06 AM
tderrick's Avatar
Official Member
Quote:
I will be staying NA...
seeing as the injectors are 15 years old, I would be replacing them anyway.
Would I need I tuner chip if I go with the 24s??
And what / where is the meter?? Is that the fuel regulator??
I guess it all depends on if I go with the TFS kit or just just spruce up the stocker stuff...
  #4 (permalink)
Old 10-31-09, 08:38 AM
frcefedlx's Avatar
Official Member
The mass air meter is what greengoblin95 is refering to. So If you do run 24's make sure you get a meter calibrated for that. Also a tune would not hurt. your computer probably won't like the stage 1 cam and any issues from that could be taken care of.
  #5 (permalink)
Old 10-31-09, 09:14 AM
final5-0's Avatar
Official Member
The OEM pump is tiny
therefore
You need to upgrade
While a 110 lph will do the job ... I'd just do a 255 unit
If you do aftermarket h/c/i and ALL supporting parts
You will push 24's to the limit at stock pressure
Again ... notice the words ... Stock Pressure
If you are gonna tune it
and
With a combo such as this ... you should
You need to decide if you are gonna run OEM pressure
or
Go with an afpr and run elevated pressures
My beliefe is to do it like Ford did it from the factory
Run the stock OEM pressure and if doing that ........
I'd run 30's
If you go this route ... save the money as afpr is not needed
Grady
  #6 (permalink)
Old 10-31-09, 09:40 AM
tderrick's Avatar
Official Member
Quote:
or
I'd run 30's
Grady
afpr = aftermarket fuel pressure regulator I take it??
  #7 (permalink)
Old 10-31-09, 10:35 AM
Official Member
Quote:
Adjustable.
Now, you asked if a tune was necessary. Your car will run on the stock tune and all, but it won't run to its fullest potential, and may have some idle/air/fuel issues down the road. I don't know about your area, but around here the most reputable tuners charge $400-$500 for a tune, and it's more than worth it. Grady was dead on about the fuel info too... I believe FRPP still has a deal where they're selling a 90mm Lightning MAF along with a set of, I believe, 36# injectors?? That could be something to look into.
Keep us all posted! I'm sure you'll love this build when it's done.
  #8 (permalink)
Old 10-31-09, 10:50 AM
final5-0's Avatar
Official Member
I hosed a bit with my info given above
I said 110 lph and should have listed the pump size as 190 lph
Grady
  #9 (permalink)
Old 10-31-09, 05:17 PM
Official Member
Grady
Who needs anything under 255, anyway?
  #10 (permalink)
Old 10-31-09, 07:43 PM
tderrick's Avatar
Official Member
Grady
Hey, Grady... Starting to read peoples sigs to get some ideas. How are you running a stock MAF with your 30 #ers...
  #11 (permalink)
Old 10-31-09, 08:31 PM
Garage
he tuned his computer. you could use the stock meter, but the tune will increase the voltage to the two wires that are in the maf to get more accurate readings for the air/fuel mixture
  #12 (permalink)
Old 10-31-09, 08:57 PM
tderrick's Avatar
Official Member
I think I'm starting to get a glimpse of the "Big Picture"
  #13 (permalink)
Old 11-01-09, 09:40 AM
Garage
as you can see, a tune is always needed for any mod to gain better numbers
  #14 (permalink)
Old 11-02-09, 06:02 PM
Black95GTS's Avatar
Official Member
Quote:
Originally Posted by 302GTS View Post
Adjustable.
Actually, your car will run like complete crap after doing that kit and not tuning it. Total a**. I would not run 36 pound injectors on this car as you would have a bear trying to finagle the duty cycle of a too-large injector. 30s are perfect for this combo as was mentioned by Dr. Grady.
Who is...
Really smart. And posts like...
William Shatner talked on Star Trek.
The stock MAF is not "calibrated" for any size injector. The stock MAF is simply a device that uses resistive elements to transmit a voltage to the computer, 0-5V, corresponding to the amount of air flow that hits the elements in the meter. The same meter is used in both the GT and the Cobra, yet the tune in the processor is different for each car. The tune is what tells the computer how to process the data. The stock MAF is physically limited, in that it can only measure up to the air flow corresponding to around 350 fly wheel horse power.
Example: If the tune is for your 19# injectors, but you have upgraded to 24# injectors, the computer will have the injectors open AS IF they were 19# injectors. So in that instance, you will run RICH, because the computer thinks you need to utilize your 19lb injectors at say 80%, when in reality you have upgraded and you should be only running at 60%. The computer does not KNOW what size injectors you have, you have to tell it via the tune.
To complicate things, your car will attempt to adapt to the new A/F ratio, which further FUBARs your vehicle.
So in conclusion, 24s will work but will be stressed out, 30s are ideal, and yes you definitely need a tune.
Adam
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
