Mustang Forums at StangNet
gear ratios
This is a discussion on gear ratios within the 2005 - 2009 Talk forums, part of the 2005 - 2009 (S-197) Mustang category; -------------------------------------------------------------------------------- ok, so i assumed my stang had 4:10 gears in it..... I know I know what happens when one ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-30-09, 08:01 PM
gear ratios
ok, so i assumed my stang had 4:10 gears in it..... I know I know what happens when one AssUmes, anyway I looked at the sticker that comes on the window when u buy it, and it says that the axel ratio is 3:31 so is that the same thing as the gear ratio?
  #2 (permalink)
Old 10-30-09, 08:16 PM
bigcat's Avatar
start with the upper hole, and if more traction is needed, try the lower hole
yes, you have 3.31s in the rear...
  #3 (permalink)
Old 10-30-09, 08:47 PM
thanks that is what i thought just had to double check though
  #4 (permalink)
Old 10-30-09, 09:07 PM
Casey4s's Avatar
Official Member
Why did you assume it was 4.10s? The 3.31s are standard in automatics and I think 3.53 in manuals.
  #5 (permalink)
Old 10-31-09, 01:00 AM
whyask's Avatar
Official Member
dear god you assumed they had 410's LOL GO GET you some 4:10's and youll POOP yourself !
  #6 (permalink)
Old 10-31-09, 05:34 PM
i have a 08 gt 5-speed and it came with 3.31 in it
  #7 (permalink)
Old 10-31-09, 07:48 PM
i have an 09 5-speed, i never have figured out how gear ratios work i thought the lower the the number the better, cause that number tells you how many times the drive shaft spins before the tires do, so i figured lower was better, for some reason i thought 4.10 was standard and everyone was swapping to 3.73 and 3.53 lol.... i obvisouly misunderstood what i read.
  #8 (permalink)
Old 11-01-09, 10:56 PM
Official Member
Garage
its 3.55 actually and it all depends on what you're doing with your car, if you have a turbo setup then a higher gear ratio like a 3.55 or 3.73 will actually be more beneficial and help you build boost faster because it puts more load on the motor. but for N/A setups you want a lower gear like a 4.10 or 4.30 and if you really want to get serious even a 4.56
  #9 (permalink)
Old 11-02-09, 10:29 AM
Garage
Quote:
He has 3.31's, those are standard in all GT's since at least '08. And that's what his sticker says.
  #10 (permalink)
Old 11-02-09, 11:48 AM
Official Member
Garage
I know he has 3.31's I was just sayin that the other gear is a 3.55 not a 3.53 and I'm pretty sure it depends whether it's an auto or stick as to which gear you get. I could be wrong though
  #11 (permalink)
Old 11-02-09, 01:42 PM
Ken04's Avatar
Official Member
Garage
Quote:
me too, 05 GT manual.
  #12 (permalink)
Old 11-02-09, 05:31 PM
ct07gt's Avatar
Official Member
3.31 is standard for auto and manual, 3.55 was optional on the manual. I think it was a $155 option on my car, which is an 07. The GT500 has a 3.31, I think the Shelby GT and the Bullit might have had 3.73. Not sure on the last two.
  #13 (permalink)
Old 11-02-09, 08:03 PM
Garage
Ahh, got ya. The 3.55's were a $300 option when I ordered mine witch was late in the '08 model year.
  #14 (permalink)
Old 11-02-09, 08:54 PM
j_lutter31's Avatar
Official Member
Quote:
Originally Posted by herm25 View Post
i have an 09 5-speed, i never have figured out how gear ratios work i thought the lower the the number the better, cause that number tells you how many times the drive shaft spins before the tires do, so i figured lower was better, for some reason i thought 4.10 was standard and everyone was swapping to 3.73 and 3.53 lol.... i obviously misunderstood what i read.
Ok, pretend your car has a 1:1 gear, it could go really fast but it would take a while to get there. As you increase your gear ratio, your tires spin slower with respect driveshaft, this increases acceleration, but decreases your top speed, (hence it increases your speed at any given rpm, that's why some people complain about gas mileage with 4.10's)
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
