Mustang Forums at StangNet
Stang is on Jackstands
This is a discussion on Stang is on Jackstands within the 94-95 Talk forums, part of the 94-95 Tech category; Well took the car to the local smog test shop here in Cali and the car failed due to the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-30-09, 09:49 PM
88stang88's Avatar
Garage
Well took the car to the local smog test shop here in Cali and the car failed due to the egr. Pushed my final button with the California Laws,gave me the reason to garage it and start the madness of mods. Out with the old stock exhaust and in with new full exhaust and h/c/i setup. Should be done mid Jan. And it will be Registered in Illinois where im originally from which requires no emissions.
  #2 (permalink)
Old 10-31-09, 05:11 PM
Garage
good luck, what combo are you thinking about going with?
  #3 (permalink)
Old 10-31-09, 08:57 PM
Pokageek's Avatar
Official Member
Good luck. I wanted a stroker engine putting out 400+rwhp, street friendly, non-forced induction over 2 years ago. I was getting there until I got some bad advice and threw 42# injectors and LT's at it. Then all hell has broken loose and its become a $$$ eater guessing game trial and error Hell. I am hoping the last bit I am dumping into it this week is final.
  #4 (permalink)
Old 10-31-09, 10:10 PM
88stang88's Avatar
Garage
going with a nice trickflow set up...buying the kit straight from trickflow. H/C/I,doing a shift kit on the tranny and full exhaust. Debating gears...i have drove it back and forth from st.louis to cali a few times so idk if i wanna be able to do that anymore or not.
  #5 (permalink)
Old 11-01-09, 12:28 AM
Pokageek's Avatar
Official Member
You'll be fine. I had the same kit on my 306 and it rocked. I had the 3.90 gears and it really was perfect.
  #6 (permalink)
Old 11-01-09, 11:14 AM
88stang88's Avatar
Garage
did you have a 5 speed or auto tho? I still have the auto but didn't feel like doing to t-5 conversion so i figured a shift kit would at least improve.
  #7 (permalink)
Old 11-01-09, 12:07 PM
Pokageek's Avatar
Official Member
db post
  #8 (permalink)
Old 11-01-09, 03:58 PM
Pokageek's Avatar
Official Member
Yes, I had a 5 speed. Shift kit will make the trans last longer and pretty cool to boot. Just make sure you DO get the right gears so your car doesn't actually go slower lol. Shifting the power band up in an auto can do that.
  #9 (permalink)
Old 11-02-09, 07:33 PM
88stang88's Avatar
Garage
yea and a suggestion on gears that WONT make it slower?
  #10 (permalink)
Old 11-02-09, 09:14 PM
Pokageek's Avatar
Official Member
Its preference and yo usaid you would be driving on long trips. I'd prolly go 3.90 with an auto as 4.10's would push it just over the edge for my preference. I'll find you that gear calc so you can decide for yourself. Some peeps will tell you to go 4.10 or 4.30 but dont let anyone tell you awe, its not that much difference. BS, every 125rpm adds up for every tooth you go higher. But it all comes down to personal preference. I wouldn't go less than 3.73 gears tho.
Ford Mustang: Mustang Tech: Calculators & Decoders: RPM Calculator
  #11 (permalink)
Old 11-03-09, 09:46 AM
88stang88's Avatar
Garage
well after a year or so i doubt i will be driving more than 20-25 minutes on the highway ever...so who knows
  #12 (permalink)
Old 11-06-09, 07:37 PM
88stang88's Avatar
Garage
Just got done taking off the stock mid-pipe and the mufflers,put the mufflers on a shelf for a later day,but mid-pipe is off for good,ran out of light and broke my drop light so tomorrow i will be taking off the smog and a/c...surprised how easily the nuts on the flange to the manifolds came off
  #13 (permalink)
Old 11-07-09, 07:39 PM
88stang88's Avatar
Garage
Removed all the smog today,except the tube running along the back side of the block...anyone know much about it? It is just bolted there for stability correct? not any other reason i could think of
  #14 (permalink)
Old 11-07-09, 09:58 PM
chaos254's Avatar
are you talking about the metal tube that runs to the back of the head? you need to either plug that tube or plug it where it comes out of the head.
  #15 (permalink)
Old 11-08-09, 01:24 AM
88stang88's Avatar
Garage
yea i thought so... i believe its a 5/8 to plug the head,anyone know for sure?
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
