Mustang Forums at StangNet
Bent the hell out of my jacking points, any issues?
This is a discussion on Bent the hell out of my jacking points, any issues? within the 4.6 Tech forums, part of the 4.6L Mustang category; Apparently this is a common issue as I came across a prior thread on here. Will this cause any problems? ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-01-09, 07:41 PM
Apparently this is a common issue as I came across a prior thread on here. Will this cause any problems? Couldn't really get under there to see after I released the jack but it looks like just the sheet metal was bent. That middle point (last pic) probably wasn't even a jacking point haha didn't realize how soft it was. Just saw the little indentation like most other standard jacking points and went for it until I heard the sound and cringed.
I need some subframes. MM good? Worth the extra $25 for powdercoated?
  #2 (permalink)
Old 11-01-09, 09:15 PM
1low03gt's Avatar
Official Member
You need some "jacking rails".
They are a god send.
The dealership i bought my GT from did the same to mine.I had them straighten it all back as good as they can,then i bought some Kenny Brown jacking rails.They go along the inner part of that pinch/weld seem of the rocker to give it strength.
  #3 (permalink)
Old 11-01-09, 09:17 PM
I just bought some MM full length subframes earlier. I can just jack along those can't I?
I'll ask Ford next time I go down there what it would cost to have it straightened back out. Prob an arm and a leg.
  #4 (permalink)
Old 11-02-09, 06:46 AM
merc123's Avatar
I jack elsewhere now. I bent one so bad it started to screw up the body panel on the right side.
  #5 (permalink)
Old 11-02-09, 07:01 AM
Official Member
Garage
i use the k member to jack mine. i did the same the thing to mine.
  #6 (permalink)
Old 11-02-09, 08:43 AM
bhuff30's Avatar
Agreed, not the best place to jack from. The only time you should jack from there is when using the scissor jack to change a flat tire on the side of the road, in the rain. I always jack the front using the K member and the rear on the frame. If I just want the tire in the air to rotate them or change tires, I jack on the control arm, near the tire as possible, both front and rear.
  #7 (permalink)
Old 11-02-09, 11:13 AM
O-G
Quote:
Yes, you can.
  #8 (permalink)
Old 11-03-09, 08:51 PM
Cool, thanks guys.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
