Mustang Forums at StangNet
Adjustable crane rocker arm problems
This is a discussion on Adjustable crane rocker arm problems within the 5.0 Tech forums, part of the 5.0 Mustang category; Ok i am having a problem. I started my car and noticed a ticking noise under the valve cover. So ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-02-09, 10:26 AM
Ok i am having a problem. I started my car and noticed a ticking noise under the valve cover. So i took it off and noticed that 2 of my rockers had came off/loosened. I tried tightening them and started the car and the same 2 did the same thing again. I am wonderin what could this be? Why are they coming a loose? i am using the locks and everything. Could it be that i need to clean them off and let them dry before i try again? could it be that the oil that are in the grooves now from the nut and lock coming off?
Has anyone else ever had this problem? if so how did you fix it?
  #2 (permalink)
Old 11-02-09, 01:17 PM
Garage
the center of the rocker itself that pivots, do you have it facing the right way? there shlould be a flat spot and the other side is more of a bevel. you need the flat spot facing down. you might not be getting enough bite on the rockers.
  #3 (permalink)
Old 11-02-09, 01:28 PM
Dark Knight's Avatar
Check the studs too, to make sure they aren't comming loose.
  #4 (permalink)
Old 11-02-09, 02:05 PM
Ok i will check again to make sure they are on the right side. I need all the advice and ideas i can get to try and get this working
  #5 (permalink)
Old 11-03-09, 10:37 AM
Ok, so i checked again yesterday and what i found is a lot of my studs were not as tight as they could be. So i basically tighted all of them and reset all the rockers... Put everything back on and its fine... Finally after taking things apart a couple of times. Now just to figure out how to stop this whistling noise from my throttle body....
Thanks for the help everyone
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
