Ok, well it's not because they installed battle boxes then. By floorboards, you mean it sticks down an inch on the bottom side of the car I assume. The torque box is the area that the lower control arm bolts too. The ABS sensor comes out through a hole in the bottom right near where the lower control arm bolts in. Battle Boxes are a product made by Wild Rides that re enforces that torque box area in order to keep them from getting distorted when you run the car on slicks.
Kurt
