Mustang Forums at StangNet
Bad T5 tailshaft bushing
This is a discussion on Bad T5 tailshaft bushing within the 5.0 Tech forums, part of the 5.0 Mustang category; So, on my 82 GT, which I rarely drive, I recently noticed a loud clucking noise coming just from underneath ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-03-09, 01:58 AM
At1Maverick69's Avatar
Official Member
Garage
So, on my 82 GT, which I rarely drive, I recently noticed a loud clucking noise coming just from underneath the trans tunnel. I thought it was just the U-joints, so I checked them, though there wasn't any play, I replaced it anyway, drove it and noise was still there. The DS bolts are tightened to spec and are brand new, IRS center section has less than 20k off a buddy Cobra that has never been abused, whatsoever.
I investigated further and found a very minimal amount of play coming from where the slip yoke goes into the tailshaft. Is that an indication of a bad bushing?
Thanks in advance all
  #2 (permalink)
Old 11-03-09, 10:33 AM
Official Member
Is the outside diameter of the Cobra DS's trans yolk the same diameter as the OEM shaft's yolk?? Any tailshaft leakage evident? Bushing could be worn after all these years. Milage on car?
Make sure the E-brake workings above the DS in the DS tunnel are not making contact with the DS. Marks in DS?
GT
  #3 (permalink)
Old 11-03-09, 03:03 PM
Official Member
Garage
GT
I am using the FRPP DS even before I did the IRS swap, I just replaced the rear flange and u-joint to mate to the IRS, So the yoke is made for the T5.
No tailshaft leakage at all, fluid was replaced about 2k miles ago, the tranny itself has approx 60k off a buddy's dad car, not abused at all.
As for the parking brake stuff, I don't have the cables yet, so I took off everything underneath that was hanging down before installing the DS, and I check for clearance everywhere, no sign of any contact anywhere.
  #4 (permalink)
Old 11-03-09, 04:23 PM
Mustang5L5's Avatar
Garage
I'd say yes, but it's such a PITA to replace that bushing on the car.
I have a FRPP AL driveshaft and a fresh rebuilt T-5 with new bushing. Entire setup has 600 miles on it. I just checked and i have ZERO play in the yoke
  #5 (permalink)
Old 11-04-09, 11:41 PM
Official Member
Garage
OK, Thanks for the info. I knew that could be it, but I needed some of you guys' opinion. So, I figured the tranny should be out of the car, but does anyone have a link or something that shows how to replace one? Thanks again SN!
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
