Mustang Forums at StangNet
T5 shifting problems, 2nd to 3rd
This is a discussion on T5 shifting problems, 2nd to 3rd within the 94-95 Tech forums, part of the 5.0 Mustang category; This one seems kinda weird to me, but I don't know the T5 well enough to say for sure it's ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-03-09, 06:02 PM
Chythar's Avatar
Official Member
This one seems kinda weird to me, but I don't know the T5 well enough to say for sure it's the synchros. This issue just started in the past week or so. When shifting from 2nd to 3rd, sometimes it feels like the gears aren't matched and it feels like a tooth or two on the gears catch before the shifter clicks into gear. Kinda like a "thump" "thump" in the shifter handle when it happens. There are no shudders or any other feelings in the car; this is all felt through the shifter handle. The problem is, it's not consistent; it only happens sometimes. I have yet to be able to reproduce it reliably. I can shift fast or slow, RPM's high or low, rev match or not, and most of the time the shift feels normal.
There are no problems shifting up or down into any other gears. I can skip 2nd (1st to 3rd) without problems. I can shift from 4th to 3rd without a problem. Just 2nd to 3rd.
The clutch starts to engage about 1/3 of the way from the floor from neutral, so I'm guessing that's about where it will catch in all gears. I still have the stock clutch cable and quadrant; they came with the car when I bought it 8 months ago.
Questions: Is this a synchros problem? Or possibly a stretched clutch cable and/or a quadrant flexing issue? I'm not sure where to start.
  #2 (permalink)
Old 11-03-09, 06:09 PM
Official Member
Since it's only in that one gear, I gather it's a synchro that has started to wear out. I wouldn't rule out a clutch issue though. Sometimes transmissions are more peticular about clutch disengagement in different gears.
Kurt
  #3 (permalink)
Old 11-03-09, 07:06 PM
Chythar's Avatar
Official Member
Ah, forgot to mention that. The clutch is new as of this summer, it's a King Cobra Clutch. New pressure plate, throwout bearing and steel TB retainer, and resurfaced flywheel too.
I've been experimenting with the issue, to see if I can get it to reliably repeat. No luck there, but I can reliably get it NOT to happen if I make sure to push the clutch pedal all the way to the floor. In the other gears, the pedal doesn't have to be all the way on the floor to shift. I was wondering if my clutch cable had stretched just enough for 3rd to have a problem, but the rest were still OK.
Thanks for the input, Kurt.
  #4 (permalink)
Old 11-03-09, 07:24 PM
Official Member
It's possible. You might want to buy a firewall adjuster to see if you can get it to go away. If that doesn't fix the problem, then it's probably that synchronizer. The T-5s come with carbon fiber synchros, and they shed the tips pretty easily. It's pretty cheap to fix if you're not scared of popping your transmission open yourself.
Kurt
  #5 (permalink)
Old 11-03-09, 07:42 PM
While at a stop, you can test clutch disengagement by attempting reverse before 1st. If it wants to grind, you either need to press harder on the clutch pedal or adjust the cable.
If it's a synchro, you will probably notice it's more pronounced while the engine/trans is still cold and it's cold outside.
  #6 (permalink)
Old 11-03-09, 08:30 PM
Chythar's Avatar
Official Member
Well, it never really gets that cold her in Los Angeles as it would in Delaware, but I haven't noticed a difference between cold and warm with this gear. I'll keep an eye on it tho.
  #7 (permalink)
Old 11-04-09, 12:15 AM
Adam95GT's Avatar
Official Member
syncros or fork.
  #8 (permalink)
Old 11-04-09, 12:34 AM
Chythar's Avatar
Official Member
The fork? How so?
  #9 (permalink)
Old 11-04-09, 12:36 AM
davis3's Avatar
Official Member
Garage
Quote:
Originally Posted by Adam95GT View Post
syncros or fork.
Posted via Mobile Device
mine would do that when cold.
got it rebuilt.
bad syncros and bent shift fork.
  #10 (permalink)
Old 11-04-09, 01:01 PM
Chythar's Avatar
Official Member
After a bit of experimentation with the clutch pedal, I noticed it just barely starts to catch just off of the floor; lower than I thought. Sounds like it's time for a Maximum Motorsports clutch cable package.
  #11 (permalink)
Old 11-04-09, 01:37 PM
Adam95GT's Avatar
Official Member
go with a fiore and modify a stock cable... im not sure if they still are around but chris has one on his cobra and the micro click adjustment is solid and just all around bad ass..
  #12 (permalink)
Old 11-04-09, 01:39 PM
Adam95GT's Avatar
Official Member
not correct year... but here is a description if your intrested.
Fiore 96-04 Mustang Micro-Click Firewall Adjuster [MC100] : Lethal Performance, Performance parts for Ford Mustangs
I know upr makes a click style adjuster... but ill never buy any parts from them... be cause of quality and someone from UPR running their mouth to people on another forum im on and talking Smack to dave zimmerman from Team Z motorsports
http://www.yellowbullet.com/forum/sh...663#post952663
http://forums.corral.net/forums/show....php?t=1101501
  #13 (permalink)
Old 11-04-09, 03:20 PM
tderrick's Avatar
Official Member
[url=http://www.lethalperformance.com/03-04-svt-cobra-transmission-adjusters-c-16_286_289/fiore-96-04-mustang-micro-click-firewall-adjuster-p-10365]Fiore 96-04 Mustang Micro-Click Firewall Adjuster [MC100] : Lethal Performance, Performance parts for Ford Mustang
I wonder why our years aren't listed for that part at Lethal... Surely the 96-04 would fit....
  #14 (permalink)
Old 11-05-09, 07:26 PM
Official Member
I use this adjuster, and it works great. $20 cheaper, and it works with any cable.
Steeda Firewall Cable Adjuster - '79-'04 Ford Mustang
Kurt
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
