Mustang Forums at StangNet
SCT tuner question
This is a discussion on SCT tuner question within the 4.6 Talk forums, part of the 4.6L Mustang category; hello, A friend of mine has a SCT Xcal 3 tuner. He has 3 different tunes for his truck. I ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-03-09, 09:34 PM
Garage
SCT tuner question
hello, A friend of mine has a SCT Xcal 3 tuner. He has 3 different tunes for his truck. I am wondering if I would be able to take his tuner, hook it up to my stang and change things like the gear ratio, trac control, tire size etc. Once you change these settings are they installed on your car, or does this require me to run a tune specific to my car. I have not done any performance mods yet, but I do plan on doing a gear swap/rear-end rebuild this winter, and want to know if I can use his tuner to change the ratio on my cars computer.
  #2 (permalink)
Old 11-03-09, 10:24 PM
VEE EIGHT's Avatar
Official Member
Cant change gear ratio's with a tuner......you need new gears.
  #3 (permalink)
Old 11-04-09, 04:47 AM
Official Member
Quote:
you need both to maintain accurate tach/odometer readings, and for some reason I doubt the tuner for the truck will work on the stang...but that is purely speculation
  #4 (permalink)
Old 11-04-09, 05:08 AM
Pearl02's Avatar
Official Member
Not true. I can change gear ratio anytime with my X-cal2. Pearl02.
  #5 (permalink)
Old 11-04-09, 08:11 AM
Garage
Like I said I am doing a gear swap and want to know if I can change it with another persons tuner... I plan on buying one down the road but not right now since there have not been any performance mods put on.
  #6 (permalink)
Old 11-04-09, 09:56 AM
oxfordgt's Avatar
Official Member
No you can not. That tuner is for his computer code it will not work on your car. Even if it's unlocked it still will not work on your car. Even if it did work you have to load a tune in your car to change anything and that would lock the tuner to your car and he couldn't use it.
  #7 (permalink)
Old 11-04-09, 10:11 AM
Garage
Thanx for the reply oxford. That was not the answer I was hoping for but you did answer my questions. I guess I will be buying a tuner sooner than later.
  #8 (permalink)
Old 11-04-09, 10:35 AM
JR@SCT's Avatar
If the X3 was made before 7/25/09, then it works just like an SF3, meaning it comes preloaded with tunes for most Fords as well as having space for custom tunes. Can't use a custom tune for another vehicle unless the PCM strategies match, but if it's preloaded with tunes you might be able to adjust one of those for your axleratio. If it is not a preloaded programmer, then you'll need a custom tune from an SCT dealer that's written for your vehicle's PCM strategy.
  #9 (permalink)
Old 11-04-09, 10:38 AM
JR@SCT's Avatar
Looks like OxfordGT already answered this while I had the reply page open and even brought up a good point about the device being married to the vehicle while it is tuned.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
