Mustang Forums at StangNet
I need a Pic!
This is a discussion on I need a Pic! within the 94-95 Tech forums, part of the 5.0 Mustang category; Please can somebody shoot a picture of there Timing marker on a 94 Mustang GT... also what is the timing ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-04-09, 03:14 PM
I need a Pic!
Please can somebody shoot a picture of there Timing marker on a 94 Mustang GT... also what is the timing supposed to be set at on the marker....Thanks
  #2 (permalink)
Old 11-05-09, 07:27 PM
True 5.0's Avatar
Official Member
I don't have a pic yet but the timing mark should be set to 0 degrees at top dead center on cylinder #1.
  #3 (permalink)
Old 11-05-09, 09:27 PM
Labora's Avatar
Hope that helps.
  #4 (permalink)
Old 11-05-09, 09:50 PM
Your awesome thanks!!!!
  #5 (permalink)
Old 11-05-09, 09:51 PM
From the other Posts people are saying the Factory timing is set at 10 BTC ?????
  #6 (permalink)
Old 11-05-09, 10:25 PM
toyman's Avatar
Official Member
Quote:
I believe what was meant was at 0 on the balancer #1 cylinder piston is at TDC. Setting the ignition timing is different and the spec is 10* BTDC.
  #7 (permalink)
Old 11-05-09, 10:45 PM
So 10btc with the spout out is Factory Timing?
  #8 (permalink)
Old 11-05-09, 10:48 PM
Official Member
Correct.
  #9 (permalink)
Old 11-06-09, 07:41 AM
Official Member
Where is the correct way to set the timing, as in picture you see i'll say you have the top of the marker the middle of the marker and the bottom of the marker, and that pic., may have a hole in the bottom center of it, mine doesn't so I'm never sure where is correct point since my marker has no holes, mark lines or anything on it, so where is the correct point.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
