Mustang Forums at StangNet
Ford Aerostar AWD Aluminum D/s Qs.
This is a discussion on Ford Aerostar AWD Aluminum D/s Qs. within the 5.0 Tech forums, part of the 5.0 Mustang category; Ok, so I bought an Aluminum Drive shaft off an AWD Aerostar. Its a '96. I read this post: http://www.stangnet.com/mustang-foru...riveshaft.html ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-05-09, 08:59 PM
DARCA's Avatar
Ok, so I bought an Aluminum Drive shaft off an AWD Aerostar. Its a '96. I read this post: AWD Aerostar Aluminum driveshaft
So what I want to know is what isn't mentioned in this post.
1. Will the rear flange bolt right up to the rear-end? Or should I reuse the one on the old D/S?
2. What U-Joints should I use? Aerostar U-Joints or Mustang U-Joints?
3. The yoke (that goes in to the tranny) has 27 splines, Do I need to use the old one or is this one fine?
Thanks.
Once again Aluminum Drive Shaft off a 1996 AWD Aerostar.
  #2 (permalink)
Old 11-06-09, 10:46 AM
SMOKEDYA's Avatar
Official Member
I did the exact same thing,and i'm trying to remember.But i'm 99% sure the yoke into the trans (if a T-5) is the same. the rear u joint needs changed and you need to use the old flang off the stock mustang drive shaft.Take the u joint to napa and tell them this is what your doing. The new u joint one side is wider then the other so you can adapt the 2 together.Here ya go this should sum it all up!
AWD Aerostar Aluminum driveshaft peace
john
  #3 (permalink)
Old 11-06-09, 01:23 PM
driveshaft
I just did this a week ago. I used a 96 aerostar drive shaft and my mustang front and rear yokes along with 2 u-joints from napa # 353 . I couldnt use the aeorstar front yoke because it had a balancer of some sort pressed on to it and on the rear the flange was diffrent spacing. Using the 353 u-joints and your mustang yokes should work fine
  #4 (permalink)
Old 11-06-09, 04:28 PM
Garage
just awd driveshaft fit or i can use any one???
  #5 (permalink)
Old 11-06-09, 06:39 PM
SMOKEDYA's Avatar
Official Member
click my link i posted above! peace
john
  #6 (permalink)
Old 11-06-09, 09:02 PM
DARCA's Avatar
I actually quoted that link in my original post, it says that the '96 AWD D/S will bolt right in.
Or did I miss something in there?
  #7 (permalink)
Old 11-07-09, 11:41 AM
SMOKEDYA's Avatar
Official Member
Oh **** sorry man i didnt click your link at first.But just go by what we all did in the link you and i posted and your golden! Nothing else to change. peace
john
  #8 (permalink)
Old 11-07-09, 03:35 PM
DARCA's Avatar
Haha, thanks man I will be doin that.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
