Mustang Forums at StangNet
Squealing coming from rear Pass. Wheel
This is a discussion on Squealing coming from rear Pass. Wheel within the V6 Tech forums, part of the 94-04 V6 Mustang category; Hello all, I have a 2000 mustang with 64000 miles on it and it just started this squealing and grinding ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-06-09, 05:07 PM
Exclamation Squealing coming from rear Pass. Wheel
Hello all,
I have a 2000 mustang with 64000 miles on it and it just started this squealing and grinding sound coming from the rear passenger side wheel(Drive wheel if im not mistaken).I checked the diff. fluid it was fine,took off the breather cap on that axel and cleaned it alittle.There is no leak.
Im not really sure where to turn next, I thought mabey the brakes but ive never heard of brakes making a grinding noise.The Rotor is cut on that side.
I also thought wheel bearing.
Any help would be much appriciated
  #2 (permalink)
Old 11-07-09, 11:36 AM
Skymarshal's Avatar
Official Member
The rotor is cut? You have a groove in the face of the rotor? Your brake pad is probably worn through the metal and the steel backing plate is damaging the rotor. If you're lucky a shop will still be able to turn the rotor and get rid of the groove.
Also make sure to check that the caliper is not sticking, and make sure there's no foreign object stuck there.
  #3 (permalink)
Old 11-11-09, 03:11 PM
I changed brakes and rotors.The noise stopped.I never heard of brakes making a grinding sounds.
Reply
Tags
axel, grinding, squealing
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
