Mustang Forums at StangNet
Removal of the Smog pump
This is a discussion on Removal of the Smog pump within the 94-95 Tech forums, part of the 5.0 Mustang category; How long and difficult is the job?...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-06-09, 07:51 PM
88stang88's Avatar
Garage
  #2 (permalink)
Old 11-06-09, 08:16 PM
davis3's Avatar
Official Member
Garage
Quote:
Posted via Mobile Device
not too hard.
search "how to install fox body smog pump".
should have all the info you need.
  #3 (permalink)
Old 11-06-09, 10:25 PM
Official Member
It's a couple of bolts and some hoses. You can either reroute a shorter belt, or get a smog pump delete kit, which is just an idler pulley.
Kurt
  #4 (permalink)
Old 11-06-09, 10:50 PM
88stang88's Avatar
Garage
ya i had intentions of reroute with smaller belt...know the size by chance
  #5 (permalink)
Old 11-07-09, 08:01 AM
Official Member
Most of them are about 89.5". You need to reroute it the opposite way around water pump and crank pulley.
Kurt
  #6 (permalink)
Old 11-07-09, 09:44 AM
88stang88's Avatar
Garage
alright...thanks for the help...it helps a ton,considering autozone is 8 miles from my house and i would be doing the test & swap...
  #7 (permalink)
Old 11-07-09, 02:39 PM
Official Member
DO a search--it depends on what other accessories you are or are not running.
  #8 (permalink)
Old 11-14-09, 01:53 PM
95five-oh's Avatar
Official Member
will this affect the car passing emissions?
  #9 (permalink)
Old 11-14-09, 02:17 PM
Official Member
Quote:
Not sure how each state/locality tests, but you're guaranteed to fail a visual inspection, and it's highly likely to fail a sniffer test, although I don't really understand how the emissions system works to say definitively.
  #10 (permalink)
Old 11-14-09, 08:07 PM
Official Member
I seriously doubt any emissions place is going to be able to tell that you have removed your smog pump. I wouldn't worry about the visual at all, they generally just look at the catalytic converters. The smog pump is there to bring the converters up to temperature. Once the car has reached operating temperature, it serves no purpose. That is why most modern cars have electric smog pumps. Removing the smog pump should have no effect on your emissions test, so long as you give the car for 15 minutes prior to the sniffer.
Kurt
  #11 (permalink)
Old 11-14-09, 08:33 PM
Official Member
Quote:
Kurt
Alaska IM looks at everything, under the hood, under the car...
They also require the car to cool down prior to hooking it up, so you're getting cold start data.
I'd certainly recommend doing some detailed research on your particular state's requirements before you go pulling everything.
  #12 (permalink)
Old 11-14-09, 10:59 PM
Official Member
Yeah, but not many states are like Alaska.
Kurt
  #13 (permalink)
Old 11-15-09, 06:30 PM
88stang88's Avatar
Garage
The car is currently registered in california but im registering it in illinois where we dont have smog or emissions of vehicles 96 or older. So im taking off the smog pump,cat's and all stock choker parts!
  #14 (permalink)
Old 11-15-09, 07:34 PM
The_Mustang's Avatar
Official Member
I think the biggest pain in the butt is removing the crossover tube that bolts to the back of the heads. Super easy if the trans is out!
The size I put on my car with A/C and no smog was 905K6 which is a 90 1/2" belt. It is tight too, took a few minutes to muscle it on there.
  #15 (permalink)
Old 11-15-09, 07:45 PM
88stang88's Avatar
Garage
im removing the a/c as well
  #16 (permalink)
Old 11-15-09, 08:02 PM
Official Member
hmmm, you might want to add that to your original post so folks can recommend the proper belt for ya. I've never taken my A/C system out so I'm afraid I don't have an answer for you. We Floridians can't survive without our A/C!
On a side note, if you're interested in selling the huge A/C line that runs from the condensor to the compressor and back to the firewall, I really need one of those.
  #17 (permalink)
Old 11-15-09, 09:13 PM
88stang88's Avatar
Garage
im in cali desert myself right now...and i am use to the heat...it sucks but ive done it without a/c for so long that im ok...and im sorry but it is already sold to a friend with a 94 gt out here that needed it,might be able to locate ya one tho!
  #18 (permalink)
Old 11-15-09, 09:14 PM
88stang88's Avatar
Garage
and i believe the 900k6 was the proper belt without a/c and smog
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
