Mustang Forums at StangNet
Bad Vibration
This is a discussion on Bad Vibration within the 2005 - 2009 GT Tech forums, part of the 2005 - 2009 (S-197) Mustang category; So I really hadn't noticed this in the past but it seems to of gotten worse as of lately (maybe ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 GT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-07-09, 07:46 AM
COBESGT's Avatar
Official Member
Bad Vibration
So I really hadn't noticed this in the past but it seems to of gotten worse as of lately (maybe I'm just more in tune to it?). When I get up to higher speeds and under heavy acceleration, there is a really bad vibration, almost like a tire is out of balance. The vibration is not in the front, as it can not really be felt in the steering wheel, it's either coming from the middle or rear of the car. I was thinking about doing a tire rotation to see if it changes at all, but then I was thinking that it could be coming from the driveshaft. Anyone else ever experience this same type of concern? All help is appreciated.
  #2 (permalink)
Old 11-08-09, 07:19 AM
dont know if this is ur problem but mine did the same thing. i had spacers in there from the dealership. took it to a local tire shop they removed em and no problems since.
  #3 (permalink)
Old 11-08-09, 02:27 PM
tommyroc's Avatar
Official Member
Garage
Before you drop a few hundred on a driveshaft why don't you have your tires checked, check the condition and the balance that will be the easiest and cheapest thing to do first.
  #4 (permalink)
Old 11-10-09, 04:53 PM
Wind-Farmer's Avatar
Official Member
Garage
I removed my spacers when I had a vibration, they did nothing. I had my tires realigned with a GOOD machine and the problem was fixed.
(note my vibrated fresh off of a balance, ford ordered a new machine and re did it bam, perfect)
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
