Mustang Forums at StangNet
ticking....
This is a discussion on ticking.... within the 4.6 Tech forums, part of the 4.6L Mustang category; My engine starting ticking yesterday. I got on it to pass some one and noticed it. I thought it might ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-07-09, 12:17 PM
usaf_branham's Avatar
ticking....
My engine starting ticking yesterday. I got on it to pass some one and noticed it. I thought it might be header tick, but i opened the hood and stuck my ear near the kenne bell and it sounds like its coming from the intake / head area. I dont hear it at idle, only 2200+ rpm, cant hear it with the windows down. Im hoping it is just an injector or something clicking like hell. I would hate to find out there is something going on with a lifter or something. There is no loss in power, it still pulls like a monster. Any ideas?
  #2 (permalink)
Old 11-07-09, 03:41 PM
twogts4us's Avatar
Official Member
Garage
Checked your oil level, both engine and SC? Let's start there...
  #3 (permalink)
Old 11-07-09, 05:28 PM
trinity_gt's Avatar
Official Member
Check the spark plugs. Make sure they're all tight and not about to blow out.
  #4 (permalink)
Old 11-07-09, 05:55 PM
mrvax's Avatar
Stay thirsty my friends
These things can be hard to find by ear. It could easily be the header/gasket and needs to be tightened.
  #5 (permalink)
Old 11-09-09, 02:41 PM
I was looking for a tick just this past week on my car. My old man showed me a nice trick.
Use a standard screw driver with a long shaft (18-24 inches) with the metal end on the component and the handle tight to your ear. It really amplifies the sound. Keep moving it around on different parts of the engine. It will take some time, but very accurate.
  #6 (permalink)
Old 11-09-09, 04:12 PM
Official Member
+1 on check the torque your spark plugs (11 foot-pounds) and oil.
Recommend getting an oil filter cutter. Inspect the oil filter looking for metal on the filter element. If found, this will signal something bad about to happen.
My Son's 2005 F150 started with a tick before dropping a valve. Turned out to be a lifter. However, the evidence was in the oil filter before it actually failed. Would have been a lot easier to fix before the valve dropped (head job/lifter replacement vs new engine).
There is a TSB that might apply here (doubtful as TSB describes tick at idle). The TSB is interesting as it includes other things to check that may cause the tick.
Article No.
03-25-6
12/22/03
ENGINE - ROMEO BUILT 4.6L 2V - TICK NOISE FROM ENGINE - ENGINES BUILT BEFORE 9/17/2003
FORD:
2001-2004 CROWN VICTORIA, MUSTANG, E SERIES, EXPEDITION, F-150
2002-2004 EXPLORER
LINCOLN:
2001-2004 TOWN CAR
MERCURY:
2001-2004 GRAND MARQUIS
2002-2004 MOUNTAINEER
This article supersedes TSB 03-16-4 to update the engine, engine build date and part numbers.
ISSUE
Some vehicles, equipped with the Romeo built 4.6L 2V engine, with an "ENGINE BUILD DATE" prior to 9/17/2003 may exhibit an engine tick noise that is present at all temperatures during idle. The noise may be emanating from the valve guide area in the cylinder head. The noise may be more prevalent in the front wheel well area and may not be heard with the hood open.
ACTION
Follow the Service Procedure listed in this article to properly evaluate/diagnose the vehicle condition.
SERVICE PROCEDURE
NOTE THIS ARTICLE APPLIES ONLY TO VEHICLES WITH A "ROMEO ENGINE" BUILT BEFORE 9/17/2003 (ENGINE BUILD DATE NOT VEHICLE BUILD DATE). THE ENGINE BUILD DATE IS TYPICALLY FOUND ON THE ENGINE LABEL LOCATED ON THE VALVE COVER.
1. Verify the source of the noise by placing a stethoscope on the back of the cylinder head near the exhaust ports.
2. Verify that the noise is heard in the exhaust system (in the wheel well or catalytic converter area, from underneath the vehicle).
3. Verify that there are no exhaust manifold leaks.
4. Verify that the tick noise is still present when canceling each cylinder, by unplugging the injectors one at a time.
5. Check to make sure that the camshaft spacers are in place. If not, install cam spacers (per Workshop Manual Section 303-01) and retest vehicle.
6. Check for proper cam sprocket bolt torque, re-torque to specification (per Workshop Manual Section 303-01).
7. Check hydraulic lash adjusters for a possible "spongy" condition (refer to Workshop Manual Section 303-00).
8. Verify that the timing chain tensioner pin has been removed.
If the above diagnostics do not eliminate the noise while the cylinders are cancelled, replace the cylinder head and cam assembly with Part Number 4L3Z-6049-AA (RH) or 4L3Z-6049-BA (LH). Refer to Workshop Manual Section 303-01 for cylinder head replacement procedures.
NOTE THE REPLACEMENT CYLINDER HEAD WILL NOT IMPROVE OR REDUCE PERFORMANCE.
  #7 (permalink)
Old 11-09-09, 07:48 PM
Official Member
AWESOME TSB! One hell of a check list if anyone experiences ticking. DEF look at oil first and pray for exhaust
  #8 (permalink)
Old 11-10-09, 06:26 PM
OMG! Of all the things in the world it could have been....... one of the flipping vacuum lines popped off my dpfe sensor. Thank god it wasnt anything serious. I havent had the time to really look at it until tonight. Who would have guessed. Thanks for the help, i appreciate it.
  #9 (permalink)
Old 11-11-09, 09:17 AM
Official Member
Line missing from DPFE. Makes sense. Would make an exhaust leak. Often small exhaust leaks sound like a tick.
Wonder why it didn't throw a EGR related DTC? Maybe didn't drive enough since EGR system used mostly during cruise at part throttle.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
