View Single Post
  #8 (permalink)
Old 09-13-09, 08:02 PM
Finaltheorem47 Finaltheorem47 is offline
Quote:
Originally Posted by latamud View Post
If you're going to swap a Cobra input shaft into the Viper T56 you are defeating the purpose of having a Viper tranny. The Viper input shaft is longer and 26 spline. The trick is to get a Viper input shaft that is shortened and has pilot turned down to the Ford bearing. Or, take your Viper shaft and have it machined. The tailshaft is a different spline so you will need a Mopar yoke.
The VSS are different, I didn't use the one on the tranny for my speedo. You can swap this out for the Ford one.
I was told the shifters will not swap but if they do please tell us. MGW tells me I can't use their Cobra shifter on my Viper T56. I think the difference is the Viper shifter twists forward and to the left, where the Cobra one leans rearward centered.
I thought a 26 spline Cobra T56 Input shaft is the same strength as the Viper input shaft strength wise?
The output shaft takes a 31 spline yoke correct?
With the shifter, it sounds like your describing the 4 bolt shifter plate. I would replace that with a aftermarket short shifter unit from MGW or someone else.
Jeez, sounds like I got the wrong transmission.. what a shame, thought this would be = to or > to the viper specs.
