OL' WHITEY said:
I'm going to get flamed for this, but I've recently tried running 3 oz. of pure acetone in a full tank with good results. I can't wait to hear the replies to this. So far, I've run two tanks through and no problems. Mileage has increased by around 20 percent. I do mostly city driving and my mileage has increased from 19 to 23 without changing my driving habits at all. Check out this site for more info.:
http://peswiki.com/index.php/directory:acetone_as_a_fuel_additive I HAD to try it. It's not something I intend to do for an extended period of time, but it does work. Okay, fire up the flame throwers! I'm outta here!
Acetone is a solvent, so I have to wonder what it A.) does to engine internals, B.) if it breaks down oil (ie..blow by into the crank case), C.) what does it turn into after the combustion process, D.) does it damage the catalytic converters, and E.) wht does it change/add to the tail pipe emissions?
From
http://en.wikipedia.org/wiki/Acetone
"In chemistry, acetone (also known as dimethyl ketone, 2-propanone, propan-2-one and beta-ketopropane) is the simplest representative of the ketones.
Acetone is a colourless mobile flammable liquid with melting point at -95.4 °C and boiling point at 56.53 °C. It has a relative density of 0.819 (at 0 °C). It is readily soluble in water, ethanol, ether, etc., and itself serves as an important solvent. The most familiar household use of acetone is as the active ingredient in nail polish remover. Acetone is also used to make plastic, fibers, drugs, and other chemicals.
As a member of the ketone bodies it is present in very small quantity in normal urine and in the blood. Larger quantities can be found after starvation and in diabetic patients with severe insulin deficiency (that is untreated or inadequately treated persons); a fruity smell of the breath caused by acetone is one symptom of diabetic ketoacidosis. See ketone bodies for more information.
Acetone occurs naturally in plants, trees, volcanic gases, forest fires, and as a product of the breakdown of body fat. It is present in vehicle exhaust, tobacco smoke, and landfill sites. Industrial processes contribute more acetone to the environment than natural processes. It is found among the products formed in destructive distillation of wood, sugar, cellulose, etc., and for this reason it is always present in crude wood spirit, from which the greater portion of it may be recovered by fractional distillation.
It forms a hydrazone with phenyl hydrazine and an oxime with hydroxylamine. Reduction by sodium amalgam converts it into isopropyl alcohol; oxidation by chromic acid gives carbon dioxide and acetic acid. It reacts with ammonia to form di- and triacetoneamines. It also unites directly with hydrocyanic acid to form the nitrile of α-oxyisobutyric acid.
By the action of various reagents, such as lime, caustic potash, hydrochloric acid, etc., acetone is converted into condensation products, mesityl oxide C6H10O, phorone C9H14O, etc., being formed. On distillation with sulfuric acid (H2SO4), it is converted into mesitylene C9H12 (symmetrical trimethyl benzene). Acetone has also been used in the artificial production of indigo. In the presence of iodine and an alkali it gives iodoform.
Swallowing very high levels of acetone can result in unconsciousness and damage to the skin in the mouth. Skin contact can result in irritation and damage to the skin.
The smell and respiratory data are known mostly from animal studies. Kidney, liver, and nerve damage, increased birth defects, and lowered reproduction ability of males (only) occurred in animals exposed long-term. It is not known if these same effects would be exhibited in humans."
