Nope. Also, Heidt's now offers 5/8" shorter control arms (narrows the track 5/8" per side) to accommodate other wheel and tire sizes.BB1966 said:Reen,does the MII make the track any wider than the stock front suspension??? Thanks in advance
There are some notable differences throughout the years:Edbert said:What is different about the Cobra R's IRS and the regular one?
I assume you're referring to the red convertible. Yes, the half shafts act as control arms as well. They are designed to do this and can handle all of the loads involved. If one fails, you will have suspension failure on that side manifested as a radical change in camber, but it's built not to fail. There are thousands upon thousands of cars on the road with this design, commonly referred to as a "Jaguar IRS".67coupestang said:awesome car!! I have a dumb question about the rear end. What does it use for upper arms? I only saw the lowers and struts. are the halfshafts supposed to act like an arm? and also on that note with inboard brakes... what happens if you snap a half-shaft?
I think he was talking about the IRS on the red convertible, not the Cobra IRS above. Now I've mixed the thread all up!BB1966 said:It has upper control arms,they bolt tot the top of the cradle. Bad azz set up Reen!!!! Keep the updates comin!
That would be a good thing...who has the power??NasaGT said:Sticky this thread!
The front end is a Heidt's MII setup with a smattering of custom and modified parts to make it all fit together. There are more pics of it all on the previous pages.68 & 00 GT said:how are you doing that front end to run that rack, and pinion / coil over etc.. new K member - sorry if I missed that info posted alredy. Is there a kit for all that ?
reenmachine said:The front end is a Heidt's MII setup with a smattering of custom and modified parts to make it all fit together. There are more pics of it all on the previous pages.
