You can buy Seafoam online now!
hey what's the deal with the bottle change?
Looks the same to me? :shrug:
This stuff looks like magic mechanic in a can and it's $6.88 @ Auto Zone...
Common Reasons Service Technicians Use SEA FOAM DEEP CREEP
When a penetrant and lubricant are needed – for a multitude of uses.
Your service technician uses SEA FOAM DEEP CREEP to penetrate and lubricate many critical areas and items. SEA FOAM DEEP CREEP is even used upside down to get at difficult areas that need treating. DEEP CREEP is used in many of the technician’s services.
When a carbon cleaner is needed – to spray into carburetors of all types, throttle body throats, pcv valve or main manifold vacuum lines.
Your service technician can offer a SEA FOAM DEEP CREEP treatment as part of a pre-tune-up cleaning.
When air intakes need cleaning – causing rough idles or stalls, because throttle plates are dirty.
Your service technician can offer a SEA FOAM DEEP CREEP treatment to safely clean the throttle plates and system.
When engine fogging is required – to store engines for long periods of time without running them.
Your service technician can offer a SEA FOAM DEEP CREEP treatment to thoroughly saturate an engine internally to lubricate it and protect it from gum, varnish and moisture problems. He can perform this service or show you how to do it yourself with SEA FOAM DEEP CREEP.
When air tools need to be lubricated, cleaned and moisture removed – this should be done on a daily basis.
Your service technician can offer a SEA FOAM DEEP CREEP treatment to lubricate and remove the moisture from air tools on a daily basis. This treatment insures the longevity of the tools. He can service your air tools or show you how to do it yourself with SEA FOAM DEEP CREEP.
When a moisture disperser is needed – to disperse moisture.
Your service technician can use SEA FOAM DEEP CREEP to disperse moisture off metal parts and surfaces. It is used on wet engine parts, bolts, clamps, etc. to lubricate and keep from rusting. This service is performed when needed.
When a door lock lube & de-icer is needed – to lube & de-ice locks.
Your service technician can offer a treatment of SEA FOAM DEEP CREEP to spray into frozen or corroded locks to dry, melt ice and lubricate or show you how to do it yourself with SEA FOAM DEEP CREEP.
When a starting spray with lube is needed – for hard starting engines of all types. For best starting results, deep creep must be kept at room temperature to be effective in cold weather.
Your service technician offers a SEA FOAM DEEP CREEP starting service or can instruct you on a do it yourself process using SEA FOAM DEEP CREEP.
When a gun cleaner and oil is needed – this is one example of the many uses of SEA FOAM DEEP CREEP for do-it-yourselfers.
DEEP CREEP cleans, dries moisture, dissolves buildup of gun powder and lubricates parts with only one application.
They've always had that stuff. The standard Seafoam is still in the same old can. And yes, you can buy it online, just not directly from Seafoam. I've still got 4 out of the 6-pack I bought a few months ago. We can't get that stuff here in Canada, so I made sure I stocked up. :D
