The Acronym Decryption Thread
Here are a few more for the tech list.
PCM & EEC - Both commonly used to refer to the computer.
OL - open loop
CL - closed loop
BAP - Boost-A-Pump
TPS - Throttle Position Sensor
ACT - Air Charge Tempature (sensor)
ECT - Engine Coolant Tempature (sensor)
EGT - Exhaust Gas Tempature
A/F - Air/Fuel ratio
fastangboi said:
what is PATS? ive seen it in threads, i think it has something to do with the computer thowing codes or the guage cluster
I believe PATS is the onboard security system that allows the car to turn on only when a key with the correct code for the cars computer system is inserted into the ignition system. IE The system that is supposed to prevent people from stealing your car when they don't have a coded key that matches the cars code.
The actual acronym for it i'm not sure of, probably something like Passive Anti Theft System or something...
