Dyno results Underdrive pulleys
JTGrant
775
GA
Anyone have just results from a dyon with the only change being underdrive pulleys? I am about moded out as far as bolts-ons are concerned. I would like to add a cam but the prices are to high right now. Thanks
no dyno sheet, but the engine revs MUCH faster now. very noticable gain on my car. even my wife noticed the difference the first time she got in. :)
i didnt look at the mileage, but i think only about 1000. give the thread a few days and others will chime in with more miles on the clock.
Get the pulleys!!! I was worried about the negative effect on the water pump, but since I am running the 4.10s that turns her a little faster to compensate.
+1 on the faster reving.
No timing adjustment needed. Dyno's have been from around 5-10hp and around 10lbs of tourqe if you google it and hunt for a while. I noticed a differance when I had Steeda's installed about 6 months ago. MM & FF's most recent magazine comes with a DVD on a 05 GT piece by piece install and dyno per part. They got 10hp on the dyno with BBK UDPs.
Besides, U/D pulleys don't increase HP ? they free it up by slowing down your belt driven accessories such as your water pump and A/C which have nothing to do with the computer's stock tuning files... therefore no computer re-flashing is necessary.
A bump in idle speed is generally required to maintain alternator charging levels. Side effects of going with underdrive pulleys include:
Reduced A/C output in low speed driving
Reduced power steering assist in low speed driving
Reduced alternator charging at idle
Bumping the idle speed UP will only reduce these side-effects. I've used the Steedas on my 4.6 2V for about 20,000 miles and eventually just went back to the stock pulleys.
Have you experienced any negative effects?
I did experience some negatives with them on a 95 Mustang GT. They caused my headlights to brown at idle and significantly contrbiuted to an overheating problem that I had when stuck in traffic. I realize that our cars are completely different than that Mustang, but can definitely see why someone would ask the question before purchasing & installing this mod.
Marine One:
You brought up an excellent point. On my 00 Vic (4.6 2V V8), the headlights did dim at idle and got worse when I had more accessories on at the time (HVAC blower, Air Conditioning, stereo, and turn signals).
I'm never going to try underdrives again in any vehicle, but that is just me. :SNSign:
