2000 subwoofer trunk convertible
wolf39us
37
I need to know what boxes will fit in a convertible 2000
from what I got from crutchfield the measurements are
(Area in trunk for mounting a subwoofer box: Height = 7" towards front, 12" at rear, Width (front to rear) = 26" maximum, Length (side to side) = 34" maximum between wheel wells (trunk opening is only 28")
crutchfield is saying only an 8" box will fit
there has got to be a way to get bigger subs than an 8"
To be honest with you it well be hard to find a box that fits perfect. Most of the time they are hard to take in and out. I would recommend a truck box or a single if you need some room in the trunk. also depends on how much bass you want. I personally would use the Kicker L5 loaded enclosure. I can be heard around the block if i wanted to but, I enjoy my hearing so I have the amp turned down low. Just enough for me to enjoy inside
could you possibly point me to one that will fit a convertible...I found a bunch that specifically say no convertibles
and would it only be a 10" or a 12? lol
I just pointed you to one on post #3 that says it won't fit, but it will.
And yes, only one 10 inch speaker. If you want more than that, your on your own and better off building a custom speaker box for the trunk. Most pre-built boxes will not fit thru the trunk opening space.
This is what I built for my brothers 99 convertible Cobra. 2 amps and a 10" sub all fit and he can still easily get the spare tire out and haul a cooler and a couple folding chairs to the car shows...
lol it looks like you built it literally into the back seat
why two amps?? is it one 4 channel and one sub amp?
I did a 4 channel for the front and rear speakers, and a mono amp for the sub. For the box I was able to get a .75 cubic ft sealed box built under the area that the top folds onto. I was actually suprised that it all fit and there was so much trunk space left.
