F303 Ford Racing Cam Thought
It depends on what you want from the engine. I wouldn't use it w/ stock E7 heads. I also wouldn't use it with a S/C. Too much overlap IMO. I would contact Ed Curtis @ www.flowtechinduction.com and see what he suggests for your combo. He grinds some pretty awesome cams. Do it right the first time.
why wouldnt you use it with e7s?? and the f-cam has very little overlap compared to most OTS cams, of most of the common OTS cams the f-cam cam has the least overlap, the stock 5.0ho cam has a LSA of 116 degrees, the F has 114 and most other comon cams are 112 or less.
thats the whole reason i swapped from my old b-cam to the f-cam, less overlap. the b had 112. if i had the cash i would consider a custom grind but the more i think about i would rather spend the money for a custom grind with a better set of heads, my combo is still on the cheap so it works just fine.
:nonono: The F cam is one of the best and most widely used boost cams. Turbo guys swear by it, and I've seen it work amazingly well with supercharged combos as well. My buddy's car is a stock short block 302 with old school iron Windsor Sr.s, an F-303, Performer intake, and an S-trim. It made 475rwhp on a conservative, safe tune at only 11psi when it was 93 degrees in the shop. This fall in some much cooler temps at night it's seen 15-16psi and absolutely screws. We figure it's well over 500rwhp at these boost levels. This is also non-intercooled on 91-93 octane pump gas. I'm not going to say the F cam is the sole reason for it making good power, but 500+rwhp doesn't seem bad to me for a stock 302 with a really old school, dirt cheap, dead reliable setup.
F cam doesn't sound all crazy at idle right? It's more subtle? I'm trying to figure out what cam my car has. The previous owner couldn't tell me, but it sounds like I might have a F.
So from what I hear, it's a good cam for a stock engine with exhaust mods and bbk Sri, correct?
