HID's from vvme.com?
ok guys, got a question. A while back I ordered the single beam ballast kit, from a seller on ebay...not related to VVME. I got the 8000K kit for the 9007 bulbs...and installed them for my regular lights. Now I am wanting to get a Dual Beam Kit for Headlights, and move the single beam kit down to my foglights, but apparently the bulbs are different???
so do I just need to order 2 new kits, 1 dual beam and 1 single beam, and then just sell the other kit that I had previously?
Thanks
EDIT: I am putting on an 03 Cobra Front Bumper and Fogs, so which bulb works for the 03/04 Cobra Foglights?
Shipping time wasnt really all that bad. Ive ordered dual a dual beam 9007 kit from them and a single beam 880 kit for my fogs and both work and look great. Really simple to instal just plug and play. Only hard part about it is trying to figure out where to mount the ballasts.:nice:
the bulbs in the headlamps are not the same light bulbs used in the fog light lamps.
so i could get away with ordering some 880 bulbs, and a dual beam kit for the 9007's, and then swap my current ballasts down to my fogs, and then just swap the bulbs out and it would work?
doens't matter anyway, im not ordering from them, for some reason I can't pay with my paypal, so I will just order off of ebay, im not messing with them. if they can't have a working shopping cart and payment function, then screw 'em. all i get is some error message saying my address doesnt match up with my paypal..but I haven't changed it, and it shows it's the same.
I did the same thing and got the same message. I sent them emails asking what's up, but never got a reply so said F it and ordered from ebay. Should get them in Mon morning. yeah.
Thanks
The bulbs you need for the 03/04 cobra fog lights are the H10 bulbs.
Well I don't want you to quote me on this but I've never had a problem with blowing any part of the kit whilst looking for the right wiring combo.:shrug:
My Expedition took like 3 hours(it was 30 deg. F outside) of frustration until I tried a combo that worked.
Your talking about the three wires that go into the stock headlight plug right? I just wired mine up and they don't work but I tried switching those wire in the plug but I don't know how to switch them around without cutting the wires and just twist and tape them back together. How did you change the three wires around. :shrug:
Thanks,
STeve
Thanks,
STeve
Make sure you are changing around the three wires from the HID kit and not the factory harness plug, and no do not cut the wires it is easy to get them out without cutting. Get a very very small screwdriver or possibly a paper clip and straighten it out. Use this to poke into the backside of the clip to release the wires. They are held in there with retaining clips, just be careful not to break anything and take your time.
Thanks. I was switching the right wires but the problem was that my battery was so low from playing music while I cleaned it earlier that it couldn't power the HID's. That's how things go with me and my projects.
Here's some pics. Sorry about the flash on the camera not being off.
03GtinFLA ^^ looks good man. Glad you got everything figured out. What color bulbs did you end up going with?
Ohh, and on a side note I have heard that you should always make sure that your car is running when you have your HID's on because you could potentially harm your ballast if your battery does not have enough power to pull them by itself.
Yeah it took me all day before I figured out what my issue was with the headlights and then the fogs probably took about an hour to hook up. Thanks for the heads up about the lights. I really like these lights. THey are much much much better than the stockers. Oh and I ordered the 8000K. I was worried that they would be too blue but they are perfect. Just a slight tint of blue. Very slight tint.
i put a 50watt apexcone 5000k bi xenon in my car and its friggin way brighter than the 35 watt vvme kit i had and alot better quality but it did cost $369 shipped
then again i did buy the life time warrenty and overnight shipping.im gonna do a retro fit down the road with o.e. tl projectors to get better light pattern
