Vacuum Question (Pic inside)
That is normal, it is a vacuum line from the plenum area. It may be connected to the solenoid valve for the carbon canister. Since I don't have a Cobra upper manifold, I can't say for sure.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
this is my oil fill nipple to TB hose...so its normal with the engine running that I have vacuum on the oil filler nipple, even though its disconnected from the TB?
That is way too much vacuum from the oil filler port. You may want to check the PCV valve and make sure the filter/strainer element is installed. Also check if vacuum is present at the filler tube port after temporarily removing the PCV valve from its seat.
what do you mean by filter/strainer element?
Tried unseating the pcv. With it taken out, the car starts but will not idle with it taken out
Replace th PCV valve....... looks like the valve internals are gone (inspect the valve), allowing full manifold vacuum to be applied to the crankcase.
I got the car to stay running for a minute with the pcv taken out. When I do that the oil filler still has a little vacuum but much much less. Makes no noise and barely enough to even hold my finger on it
:shrug:
I can take the PCV out completely, and hold one hand over the PCV hole in lower and the other hand oil fill nipple and when I block off PCV hole, filler nipple pulls vacuum. Block off filler nipple and PCV hole pulls vacuum...pretty strong one. Again this is with manifold vacuum completely taken loose and capped off to test.
