Pics of project 400rwhp N/A stock block 331
Well the goal is 400 or more at the tires.
Slowly but surely this motor is coming together. Its a royal pain in the ass modding two cars at once but here is whats so far...
Shortblock:
Heads:
Next will be the Precision "race" standard volume oil pump, ARP oil pump studs, CHP hardened shaft, and Canton 7qt oil pan. I will keep updating this thread as the project goes forward. :flag:
You can do it with the 331. You'd have to spin a 302 to 7k+rpm to get in that HP range which would be crazy expensive. But you're running a 331, not a 302. KillerCanary is on his way to 400rwhp with his 331 AND less compression. He's spinning in the middle to upper 6k range which isn't that crazy. I think the trick will be in your heads. Obviously the whole package needs to be well thought out though. I have my hopes up for this one though.
I'm spinning this 331 between 7,000rpms and 7,400rpms. Shift point will be 7,200rpms unless my transmission can't keep up in which it will be 7,000rpms. The car will have 4.30 gears in it. The intake will be Trickflow Box EFI intake, 90mm TB, and some 1 3/4" headers with a 3" DR Gas X pipe with 3" Bassani custom mufflers. If it makes less than 400rwhp I'm pulling it back out and putting in the 410W with a 200 shot.
Yep, it all depends how high you want to go. 331 will get there before 302. To demonstrate, my 414 is hitting the 400rwhp mark at just about 4900 with the latest tune. I like the power down low so I dont want to push it out to 7000 but I imagine if I did it would make a lot more power. High revving motors are always cool though.
Getting a high number from small cubic inches is not all that unusual :)
I mean ... look at Formula 1 :Word:
Now ... in no way am I dissin Mr. Stopsign32v or his efforts :nono:
Using SAE RWHP (my only standard) :D
that would be 1.21 hp to each ci :eek:
Pretty high ratio when you talk daily driver street car
Most street/light strip car use combos using the OEM block & ci size
which can yield close to stock like drivability are gonna fall in
the .94 to 1.04 range ;)
From what I see ... that ain't no cruise around town combo
or
One that would be considered a mild mannered daily driver :rlaugh:
Looks like that would be a lot of fun to sneek out on the street
during the weekends :banana:
Grady
or
Grady
This motor and the car it is going in will be a 100% daily driver. Will it drive like a stock car or a H/C/I 302? Nope....
