EPIK
And use a 2-3" spacer?
Nope... A 1" spacer will work fine. I have seen a buddy of mine put 1" spacers on his 17X8" stock wheels & they sat perfectly flush with the fender lip similar to 17X10.5's.
i think some of laser's bad car juju rubbed off on me....
installed brakes thursday, but didn't have anyone to help me blees them as i don't have a brake bleeding kit..
friday, get the girlfriend to help.. i started from the passenger side rear went to drivers side rear then to passenger front and lastly drivers front... no brakes
so i do it again...no brakes.. do it again.. little bit spongy feeling...turn car on, brake pedal drops to floor back to having no brakes....
2 1/2 hours later i call my step dad..been a mechanic forever and truly knows his stuff.. tells me to bleed master cylinder then do it all over again.... so i bleed it, and repeat...
feels like a have brakes.. turn car on to take a test drive..1 click no power.... ahhhhhhh
turns out battery is toast... so i go buy a new one....put it in today(saturday) what happens when i go to start it....NOTHING!
find loose ground wire and fix it...got juice everywhere...turn key, horrible starter noise, no start and fire type smell...
now my starter is toast.... ugh...i hate cars...so theres 2 new unplanned items on my list... once this gets sorted out, if that ever happens, the headers will go in....
anyway thanks for reading my lons post :SNSign:
I think we all must have the same walmart gm low profile jack!!!
So uh, was tiffany a good helper? i remember her hating on domestic
You might be having brake bleeding issues with the abs module not allowing it to pass thru
Dont you just start thinking WTF am I getting into when stuff like that happens I hate that, but I am sure it will be worth it in the long run!
Well at least the starter went not and not after the headers were on there, that would have sucked monkey nuts
Ididn'tdoit
I thought the ABS pump cycles with the ignition and that you can bleed the pump by turning the key off and on a few times
