I'm still new to a manual transmission, not really sure how to diagnose noises and squeals yet. Just noticed tonight a metallic squeal whenever I pushed the clutch pedal in, the squeal goes away when I let off the pedal. It's noticeable when shifting at lower RPM, can't really hear it if I shift around 3K or so. It got noticeably worse on the way home, much louder. Also noticed a chirping with the clutch in and the car in neutral. Can't tell if the chirping is there while in gear, too much road noise.
After going through the search, it sounds like my throwout bearing is dying pretty fast. I wanted to confirm that with you guys before I tore things apart.
I've also read that it's better to replace the clutch, t/o bearing and input shaft bearing all at once. Anything else I need to replace while I'm at it?
Also looking for recommendations on clutches. I have no idea what's in the GT now, some sort of "performance" clutch according to the previous owner. I've been out of work for a while, so price is a big factor. I won't go cheap on the bearings, but I can't spend $500 on a clutch either.
I'm not planning on doing any engine upgrades for a while, so stock parts aren't necessarily a bad thing. But I wouldn't mind an upgrade if the price is right.
