Hey everyone, recently I learned that the 4.6 aluminum block can hold a whopping 700 hp! After searching around, I've found some stroker kits that not only will replace and outlast the stock internals under boost, but will also add some more displacement to my stock engine.
I'm gonna say this outright - I know NOTHING about engines overall. I understand the basics, but I don't really know how everything gets put together. I'm looking into a few different kits that will raise the displacement to either 298ci (4.9 stroker) or 311ci (5.1 stroker).
My question is, what kind of work will be needed to be done along with either stroker? I need a new tune, right? Also, what sort of power increase should I see over stock? (That's what I mostly am now.)
My plans include a supercharger at reasonably medium boost... But I'll probably stay below the 14s (PSI) depending on what increase stroker will give me. What should I see while still N/A??? I'll either do the stroker first or run a blower on low boost until I have the $$ for both.
Livernois is one of the most recommended kits on the web, but the fact their stroker kit will cost me the same as the Probe Industries 5.1 stroker kit is questionable. By the way, I'm thinking of opting to this rather than getting a whole new MMR block.
Thanks a lot!
New - Livernois Motorsports - 4.6L 3-Valve 298ci Stroker Rotating Assembly
Stage 3 Motorsports 1996-08 Mustang GT 5.1L Forged Stroker Rotating Assembly - 21.0 Dished Pistons
Thanks a lot!
