I'm bored, the car is clean, and I have fresh batteries. Time fer sum pitchers, boys n 'girls!
I cleaned 'er up and realized I don't have any current pics of the thing as it sits when it's not filthy. So, with the new tail lenses, here it be:
With the groovy 3G alt in there:
My ghetto-riffic overflow canister and washer reservoir/universal washer fluid pump setup, in addition to my (probably useless) mounting of the transmission cooler (I figure, even if it doesn't cool things any better than it could, at least it isn't making the fluid any hotter):
The chunk missing from the top of the timing cover that the prior owner apparently broke off while replacing the water pump. They were semi-smart enough to put a washer and nut on the back of it to (I guess) help sammich the water pump's backing plate to the pump housing, but as you can see it's got a mild leak going on and loses about 1/2 a quart every week. Leaves dried-up goopy green snot all over the underside of the pump, the timing pointer, and the lower radiator hose.
Two things I HATE about this car at present - the external fuel pump and the stupid undersized single muffler some moron put on this car:
Notice how it downsizes the pipe diameter by at least 1/4" when it goes from the flow tube to the muffler? Ugh. Peoples is so stoopid...
The part where the crossover portion of my stock Y-pipe either got squashed by road debris at some point in history, or where it (I guess) is crimped from the factory to make room for the tranny bellhousing. This has GOT to be choking things quite a bit - it's probably only like 1.5" thick in the middle.
You know your motor mounts are shot when your fan sits this far down in the shroud...
...and it's so far down you have to cut this much off the bottom half just to make the damned thing clear so it's not hitting the shroud like a buzzsaw.
