351W f4te engine block - what would you pay?
re the valve covers and clearance thing, i used comp pro magnum rockers which let me use stock height valve covers. then i didn't need a spacer.
and i have a 96-98 cobra hood with a typhoon intake and a k-member from AJE that is supposed to drop the motor about 3/4". there was a spot where it hit, but it was fine because we only had to remove a little of the bracing under the hood to fix it.
of course the typhoon is really holding the motor back, but i like the bling of it and it is already plenty fast enough for me, especially since i am 100% street and never go to the track
I tried to put fox valve covers on my engine when I built it, and it didn't clear the alternator. The oil fill neck was also in a hard place to work around. If you build a 351 stroker with nice aluminum heads, by the time you add up all the nickel and dime items, it will be over $6K.
Kurt
heh i'd have been happy if it was only 6 grand. i think i ended up closer to 10 grand all told. then again, i got all the polished stuff and agreed to all the suggestions my builder made, some of which were not really necessary
Yeah, $10K is closer to the truth. I'm just saying if you buy every single part you can used, and happen to be having sex with a machinest, then you might get it done for $6K.
Kurt
Wait? you don't have sex with your machinist? :rolleyes:
Kind of. He kind of F'd me by making me wait 7 months for my engine. I can't complain too much because of the deal I got. I gave him an old 302 short block and a stroker kit, and he gave me back an assembled stroker short block for $325. He did $1000 of machine work to my heads for $400. I might not have the best stroker engine, but I bet I have almost everyone beat on price.
Kurt
