Idle issues
Blakonblak94
38
Ok guys, so I have an issue going on. I'm running tw 170 heads, 19's, trackheat intake. Im tuning using quarterhorse. Well it seems like my lambse numbers are staying around high 11's and low 12's at idle, and my kamfr is near 1.18. Well the car has a rough idle. I'm trying to find out what to do about this. Any help?
lambses below 14.6 go hand in hand with kamrfs above 1.0, don't they?
seems to me it thinks it is lean and is trying to richen it up.
what maf do you have? can you tweak the maf transfer curve?
and what is your fuel pressure?
As I see it
He said he dl's L's in the 11's and low 12's which would be the pcm
commanding a fat mixture ... would it not:shrug:
Now if the pcm is commanding a fat mixture
Would you not expect to see K's at a value of below 1.00 which
means adaptive is trying to pull fuel
If he was seeing L's which were lean you would expect to see K's
above 1.00 cause adaptive is trying to add fuel to compensate
for the lean mixture which is opposite of what is happening here
anyhoo ... just a random thought :)
The meter's curve could be outta whack at the idle points
but
Other things could be hosing around with the idle as well :shrug:
Grady
Check fuel pressure today actually. It was high, set it at 39 with vac pulled. It's just getting bad. I'm thinking my o2's are going out. They are original to the best of my knowledge on a 80k mile car.
You can't be changing the fuel pressure or that will throw your
tuning outta whack :bang:
The best thing to do is put it back to stock
or
Better yet ... put your OEM regulator back on ;)
Grady
Stock is 39psi. That's where it is currently sitting. I'm just getting a tad frustrated. It's running really fat at idle. I can smell fuel, and it's running rough, almost like it has a miss. I'm thinking new o2's may be in line. I just don't know. I dont wanna dump money into troubleshooting if I can track the issue down.
Already checked. I had two codes that were understandable. One was vapor canister being unhooked, the other I got a 511 which is EEC permanent read only memory(Rom) test failed. Not sure what that means.
As I see it
maybe i'm having a senior moment ... here is what i'm thinking ...
when the O2 sensors report that the mixture is lean, the computer commands a richer LAMBSE to try to compensate. this results in an increase in the KAMRF.
am i thinking about it backwards?
